First post, by ace_85
Hi - wondering if I could get some help with running Tomb Raider on a Windows 7 64-bit system? I've installed the DosBox patch, but I can't get the game to actually run - Glidos crashes with the error message 'Could not load psVoodoo\Glide2x.dll'. Am I likely missing some program files or had a incomplete install of Glidos? I'm admittedly not much of a technical sort, so I'm a little in the dark here.
Here are some other system specs for the laptop, if needed:
CPU - Intel Pentium P6000 1.87GHz
RAM - 2Gb
GPU - Just the onboard Intel HD Graphics
Couldn't get much info on the mobo unfortunately, Everest doesn't recognise the model
Thanks in advance 😀
