First post, by kopierkatze
How to modify DOSBox settings when used in conjunction with Glidos?
I am trying to run "Grand Theft Auto" on Win7 x64, but it won't work.
Glidos mounts "C:\GTA\gtados" to "C:\", and then GTA won't load because it wants to access "..\gtadata\player_a.dat" on startup (which is not accessible because of the way you're mounting the directory).
Also it mounts the first Disc-Drive it finds to DOSBox, which is the wrong one in my case.
So how can the DOSBox settings modified when using Glidos?
When I manually mount the GTA directory (MOUNT F "C:\GTA"), and I try to run gtafx.exe, the game won't work either.
First the text on the screen turns from gray to white, then the screen gets black and nothing further happens.
Reply 1 of 1, by Glidos
Oops! I hadn't considered a game using ../ to access data. I'll need to change the way it works. You may be able to start DOSBox with a .bat file in a way that will work. I'll have a think about that and get back to you.
