drive switching bug
First post, by robertmo
I have noticed that glidos is not able to run a game from drives other than C:
it is entering the folder on other drive but is not switching to it and tries to run exe from c: (the content of .bat file is wrong: missing "drive:")
Reply 1 of 20, by robertmo
actually the problem is more serious as it is not restricted to C but to the drive glidos was installed on. I used to install glidos on a small partition for small programs only hence it was never working for me 😉
Reply 3 of 20, by robertmo
windows,
set PATH=%PATH%;C:\Program Files\Glidos
cd D:\TOMBRAID\
COMMAND.COM /C Game.bat
DOSDRV
gldvesa.exe Tomb3dfx.exe
it simply tries to start the game form c:\program files\glidos
cause cd D:\TOMBRAID\ doesn't go to d:, it only changes directory on D: but stays in c:\program files\glidos
Reply 5 of 20, by wd
Rank DOSBox Author
DOSBox Author
That's how it works, as GliDOS says under DOS and Windows you'll need D: to change the drive.
Or is the snippet you posted somehow generated?
Reply 11 of 20, by Glidos
Ah, that would be down to stupidity on my part. Try this one.
    Glidos.exe
    1008 KiB
    445 downloads
    v1.50b of Glidos.exe
Reply 16 of 20, by Glidos
Yeah, I knew that. 😁
I meant, what exactly did you type when you got the error? Path
needs to be of the form
<drive letter>:\<path folder 1>\ ... \<path folder n>\<exe name>
If you select the exe using the Browse button it will have that form.
