Glidos and GOG Tomb Raider
General information and assistance with GliDOS.
Postby bunkkray » 2012-7-17 @ 15:07
I could not get Glidos to work with the GOG release of Tomb Raider. Has anyone got this to work yet? Or will support be added?
On a side note I also changed my gog installation so that it had music play by following this guide.
http://www.gog.com/en/forum/tomb_raider ... d_business
Thanks
bunkkray
Re: Glidos and GOG Tomb Raider
Postby Glidos » 2012-7-18 @ 11:18
Oh right. Yes, I'll get Glidos to work with that when I can find some time.
User avatar
Glidos
Postby bunkkray » 2012-7-18 @ 15:10
Thank you :)
Ill order my copy today so I can support your effort.
bunkkray
Postby RadG » 2012-10-13 @ 21:01
Hi! Yes, i found a method to run Tomb Raider GOG in Glidos. Install Glidos and DOSBox modified version (from Glidos website), edit the file dosbox.conf inside Glidos folder and add the following lines (you must change the path if necessary):
[autoexec]
imgmount e "C:\Juegos\GOG.com\Tomb Raider 1 2 3\Tomb Raider 1\GAME.GOG" -t iso -fs iso
Now run Glidos select Tomb Raider and Adjust... select Executable tab and delete the fields under Allowed executable sizes, leave blank for no check.
If you want to play Unfinished Business, downlad this package http://ul.to/b9vr1zf2 prepared for GOG and extract the files in Tomb Raider 1 folder then, add the following lines:
[autoexec]
imgmount e "C:\Juegos\GOG.com\Tomb Raider 1 2 3\Tomb Raider 1\GOLD.GOG" -t iso -fs iso
Now the same steps, select Unfinished Business, Adjust... leave blank for no check.
RadG
Postby Glidos » 2012-10-28 @ 14:04
Excellent. Thanks RadG. I've just updated Glidos to support Images and hence GOG from the config. Your post was very useful.
User avatar
Glidos
Return to GliDOS General
Who is online
