Unfinished Business in Glidos Using GOG TR and Win7 64 bit
General information and assistance with GliDOS.
Postby hojo2000 » 2014-3-09 @ 05:51
I'm trying to install the Unfinished Business expansion levels for Tomb Raider. I am using the latest version of Glidos on a Windows 7 64 bit system. My Tomb Raider install is part of the "Tomb Raider 1+2+3" GOG package. I've been unable to find a guide for playing Unfinished Business, via Glidos, for this particular setup. If this has already been solved is there a link available to the solution? I searched but could not find one. if not how can I install Unfinished Business? Many thanks in advance.
hojo2000
Re: Unfinished Business in Glidos Using GOG TR and Win7 64 bit
Postby Sardoc » 2014-3-09 @ 14:39
Copy the "Data" folder (containing Egypt.tub, Cat.tub, End.tub, End2.tub, Cred0.pcx and Titleh.pcx) from UB installer to your TR1 game folder.
Then, download the exe pack for Glidos: http://download.glidos.net/TR1/TrAndUbForGlidos.exe
Finally, run Glidos, pick Unfinished Business, go to Adjust..., and specify where UB exe file is. Select DOSBox as the emulator.
Best of luck.
User avatar
Sardoc
Postby Wronschien » 2016-6-17 @ 11:06
Hello, I've been trying to set up Unfinished Business in Glidos for some time, I have the same config as the op (Win 7x64 and GOG version) so I tried the solution posted here but no luck. The game starts (although it is the normal menu with no mention of "unfinished business") but when I select "new game" it crashes.
Btw, the original TR1 works fine in my Glidos setup.
Wronschien
Return to GliDOS General
Who is online
Users browsing this forum: No registered users and 3 guests
