First post, by BuckoA51
Okay, legitimate problem this time I promise.
I keep getting the title screen music playing over the top of the opening FMVs and when I exit the game and go back to the desktop. I'm playing with an original Tomb Raider CD. I also tried making an ISO of it but it made no difference.
Here's what happens exactly.
1) Start GliDOS
2) Start Tomb Raider
3) Skip or watch FMVs
4) Main menu appears, music starts playing.
Then either
5) Start a game, music stops then immediately starts again and plays over the opening FMV
6) Exit the game, at which point the game exits to windows and the music stops then immediately starts again, playing on the desktop until I close GliDOS completely.
Any ideas how I can fix this irritating problem? I'm on Windows 8.1.1 Pro x64. Thanks.
Edit - bit more about my PC:-
OS Name Microsoft Windows 8.1 Pro
Version 6.3.9600 Build 9600
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name W8-GAMES
System Manufacturer Gigabyte Technology Co., Ltd.
System Model X58A-UD5
System Type x64-based PC
System SKU
Processor Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz, 3060 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Award Software International, Inc. FE, 29/04/2011
SMBIOS Version 2.4
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Model GA-X58A-UD5 Revision 2
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Locale United Kingdom
Hardware Abstraction Layer Version = "6.3.9600.17031"
Username W8-GAMES\Bucko
Time Zone GMT Summer Time
Installed Physical Memory (RAM) 12.0 GB
Total Physical Memory 12.0 GB
Available Physical Memory 7.57 GB
Total Virtual Memory 13.8 GB
Available Virtual Memory 7.58 GB
Page File Space 1.81 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Graphics Card - GTX 770
Sound Card - Auzentech X-Fi Home Theatre (Creative X-Fi chipset based)
play-old-pc-games.com
Reply 6 of 6, by Sardoc
Ok. Let's try this:
Open your CD burning software (Nero or something, I use Nero 7). Start a new Mixed-Mode CD compilation. This type of compilation stores 2 types of data: files which you can access using a PC, and music, which you can play using any cdrom device (yeah, Hi-Fi system too).
There should be 2 sections: "data" and "audio". Copy everything from the Tomb Raider CD to the "data" section, and copy the mp3 files from the audio pack to "audio" section. If needed, set the program NOT to put 2-second pauses between each audio track.
Then, burn the compilation as a .cue/.bin CD image file. If your program doesn't support saving .cue/.bin files, you can use an image converter, like MagicISO.
Go to your Glidos --> Dosbox folder, find the .conf file and open it with the notepad.
Scroll all the way down to [Autoexec] section. In this section, add this line:
imgmount d "e:\games\TR1\TR1.cue" -t iso -fs iso
Where D is the letter that Glidos and Dosbox will use as a cdrom drive.
Try this and see what happens. If you find the music way too loud, add another line under imgmount:
mixer cdaudio x:y
Where x:y are numbers (percentages) of the left and right channel, respectively. In my case, it's 50:50, which means 50% volume of the left speaker and 50% of the right speaker.
