Glidos says Wrong version of DOSBOX GOG version
General information and assistance with GliDOS.
Postby coolcat68 » 2015-3-21 @ 01:16
When I attempt to launch Glidos first it says glidos.ini failed to save. Then I get a "wrong version of DOSBOX" error. What is going on? I am using the GOG version of Tomb Raider.
coolcat68
Re: Glidos says Wrong version of DOSBOX GOG version
Postby coolcat68 » 2015-3-21 @ 01:38
I figured out why it was giving wrong version of Dosbox. The .ini file is not saving my setup, so I have to redo setup every time. But, why is it not saving?
coolcat68
Postby coolcat68 » 2015-3-21 @ 01:48
I figured it out. For some reason I did not have permission to modify that folder. I gave my self permission in the security tab of the folder of Glidos and it now works.
coolcat68
Postby Kerr Avon » 2015-8-18 @ 15:35
Glad you got it sorted out, and thanks for posting the solution, in case anyone else has the same problem.
Kerr Avon
Return to GliDOS General
Who is online
