First post, by VLC
- Newbie
The standard installed version of tomb.exe is the software engine, it certainly won't work with Glidos. What you need is the Glide version for 3dfx cards (Voodoo). Either it's located in a special directory on your Sold Out edition (I'm not familiar with that one) or you'll have to get the right executable from the Net. Eidos France is a good start.
Just back up your original tomb.exe and copy the new one in your TR folder.
In your glidos folder there's a subdirectory docs, why didn't you look inside?
Well, you could have found the same information here:
http://www.glidos.net/install.html?lang=en
