Getting TR1 to work w/ Glidos without the CD — is it possible?
General information and assistance with GliDOS.
Postby jperk » 2018-4-08 @ 05:15
If a buy the physical copy of TR1 (not the digital GOG or Steam version), is there a way to get that to work without using the CD and then getting the game to run in GLIDOS?
I know in the GLIDOS settings there is a way to run from CD or mounted iSO, but I was wondering if there is a work around from using a mounted ISO like a hex edit, non CD patch , etc.
jperk
Re: Getting TR1 to work w/ Glidos without the CD — is it possible?
Postby Kaminari » 2018-4-13 @ 10:57
The "CD Source" option is mainly used for audio tracks. If you set the "Path to Executable" option correctly, you can point to the hard drive location where you copied the content of your game CD. In the "Audio and Movies" tab, select "Use Audio Pack" to replace your audio CD tracks with the MP3 pack available on GLiDOS website.
Ryzen 2600X 4.0 GHz | Vega 56 8 GB | DDR4 16 GB | Win7-64 SP1
User avatar
Kaminari
Return to GliDOS General
Who is online
