First post, by buckeye
I downloaded the Glide/Blood exe file and installed it but not sure if I did it right. I already have the GOG version, was I supposed to install it in that directory or keep it separate per the default?
It works ok, maybe I'm expecting too much but still looks "rough" but probably need to tweak some stuff. Can anyone recommend some settings that might help? Running it per the "dosbox" toggle within Glidos.
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Intel DH61CR i3 LGA-1155 8GB DDR3 EVGA 1050ti 4GB 480GB SSD 650W
Reply 1 of 3, by Kerr Avon
What I *really* recommend is that you use the Java-built game engine semi-port at:
https://m210.duke4.net/index.php/downloads/do … ava/50-bloodgdx
It's called BloodGDX, and it is amazing, being basically a Windows port of the game engine, so it runs the original game but with all of the advantages you'd expect of a modern Windows port, such as higher resolution support, proper mouse support, easier key binding, and so on, all from the one program.
The same bloke is also working on a game engine port for Redneck Rampage, Tekwar, Witchaven, Duke Nukem 3D, and Shadow Warrior 3D, though he's not released a version for the last two games (DN3D and SW3D) yet.
Reply 2 of 3, by buckeye
Kerr Avon wrote:
What I *really* recommend is that you use the Java-built game engine semi-port at: […]
Thanks Kerr Avon, hopefully it'll work with XP SP2. I'll post what I find out here when time allows.
Reply 3 of 3, by DosFreak
IIRC, it requires Java 6+ and I think Java is still compatible with XP up to 8 Update something so you should be good.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
