First post, by Unregistered
I have done everything it told me to do and i can't install it. every time i put in intall.exe it says its not a file or whatever. HELP!!
Reply 2 of 6, by Glidos
You probably didn't mean "intall", but just in case, its "install".
If typing "install" is giving you that error, then probably you haven't managed to make the CD your current directory.
You need to put the TR CD in.  And type
D:
or maybe
E:
or maybe
F:
Depends on which drive letter your CD drive takes.
You can tell when you get it right, because typing
Dir
will display all the files on the CD, including install.exe
