Reply 120 of 407, by Eivind
- Oldbie
Eivind wrote on 2024-04-10, 14:13:Joseph_Joestar wrote on 2024-04-10, 14:05:If this emulator ever makes it to VSTi form, would it be possible to have it running on a modern system, while still being able to access it from an actual retro rig using a Roland UM-ONE mk2?
I think something similar is already possible with MUNT, unless I'm misremembering. Phil may have a video on the topic.
I'd think you could do this with the emulator in its current state already? Just gotta route the midi signal correctly on the modern computer.
I'll just answer my own post here - I hooked up a UM-ONE between my macbook and an ISA sound card, and the emulator played back the general midi from warcraft 2 just fine.
