First post, by scorp
Hi guys, just wanted to announce my voltage regulator module for Socket 5/7 mainboards with accordant Intel VRM header. In case you always wanted to convince a slow first generation Pentium mainboard to dance with an AMD K6-2/400. You can find the related information on the project site: https://github.com/necroware/s7-vrm
If you like to watch videos about retro hardware, you also can find the related topic here:
Part 1: https://youtu.be/CMiGVQbMC5U
Part 2: https://youtu.be/J0NLGfocviU
Part 3: https://youtu.be/kBPp9EAIC8I
Part 4: https://youtu.be/XV0b5Tvf5gY
Part 5: https://youtu.be/_w-_W6mnMzU
My Youtube channel Necroware
Reply 3 of 16, by Pierre32
Yep, followed these videos and it's great to see the end product.
I ended up getting my Necroware Gameport-USB adapter (and a Voltage Blaster too) from this Tindie store: https://www.tindie.com/stores/retrofletch/ Maybe he'll do these too.
Reply 4 of 16, by Joseph_Joestar
Excellent work!
Your videos are very educational for someone like me who just started dabbling in retro hardware mods and repair. They are always fun to watch as well.
Reply 5 of 16, by Repo Man11
Thank you, I've been eagerly awaiting this! Do you have anything set up for single payment donations? I'd like show my appreciation for your work, but I'm not too keen on Patreon as I just want to do a one time thing.
Reply 6 of 16, by scorp
Thank you very much! Glad, that you guys like this project and the videos. Unfortunately I don't sell anything, since it is complicated to sell such stuff from Germany, sorry. However, I'm quite sure, that sooner or later someone will build and sell those parts, usually very overpriced, but it is as it is 😉 If you want it as cheap as possible, try to build it on your own. I always tend to design my projects in a way, so they can be easily soldered by hand. Also, may be here in the forum somebody can organize and build a bunch of those modules.
I don't want to give any commercial here, but just because you ask, if someone wants to support my channel, beside Patreon, there is also paypal link in the channel description and "thank you" buttons under the videos. If you want, you can use that, but please don't feel, that you need to, it's already a big reward, if I know that I could give you some fun 😉
Reply 9 of 16, by feipoa
I'm looking forward to the final revision of this VRM adaptor. It provides a nice alternative to the overpriced, and increasingly rare, socket5/7 upgrade adaptors (Kingston, Evergreen Spectra, etc).
Will you be providing a BOM specifying normally in-stock Mouser part numbers? I saw a general guide for part specs in the docs section, which is certainly helpful, but an exact BOM for the final revision I think would be helpful for most hobbyists. I realise you aren't at the final revision yet.
I also have an Asus P/I-P55TP4XEG I'd like to test your VRM on, but I'm even more anxious to test it on a socket 5 board I have, the Asus PCI/I-P54TP4. That board I tried tirelessly [and unsuccessfully] to upgrade to PB Burst SRAM, Anyone own an Asus PCI/I-P54TP4 with pipeline burst SRAM? Planning to mod direct-mapped SRAM to pipelineburst
Do you have any socket 5 boards to test the VRM on?
Reply 10 of 16, by Sphere478
Good job 😀 the videos were quite entertaining. Suggest testing the mainboard with on motherboard cache disabled btw.
Sphere's PCB projects.
Reply 11 of 16, by totoro
Excellent project! Thoroughly enjoyed all the parts and eventually tried to build few of your VRM's for myself. It so happened that I have a Digital Equipment Corporation Venturis FX5150s which I love to tinker with and it has a VRM connector. I had an urge to upgrade it with an MMX CPU for a while now! Thank you for enabling that to happen! Happy to report that the module works beautifully!
888.79 KiB
P.S.
Would be nice to have a cheap and simple/basic revision of the module that could power just Intel/Cyrix MMX CPU, something like your initial module. People like me, with limited skills would be unlikely to push an early board to accept an AMD K6, while having lower entry point both price and skill wise could benefit more people. Especially those who just want to throw an MMX and move on.
P.P.S.
Actually I have built 5 modules, but I still have to make or find those darn inductors for the other four and then obviously test them. However, I might be open to sell the excess with a slight overprice and recoup the cost 😉
Penguin Workshop
https://viekelis.lt
Reply 12 of 16, by Sphere478
Hey all, I got this vrm from another member, they assembled it and tested it before giving it to me.
I have so far only tested it with over current protection present.
It trips it every time in two different motherboards so far.
Without vrm installed the system functions fine.
Any ideas? Dare I try without the protection? Are the capacitors of the unit too large? Is that why?
    567.17 KiB
    790.77 KiB
Reply 13 of 16, by vetz
That ATX to AT adapter is not really suited for later setups like fast/powerhungry Socket 7 and Slot 1 boards.
I always got over current message when I tried to use it on those boards.
Reply 14 of 16, by Sphere478
Yeah. It does seem to be the caps. The vrm works with a straight adapter. And I noted the problem with a recapped board I have. Seems low resistance/higher value modern caps can cause issues.
I was able to get the recapped board to boot by pressing the power up multiple times on the over current device to precharge the caps
Reply 15 of 16, by darry
Sphere478 wrote on 2024-02-05, 01:08:
I wonder if delaying the power good signal's assertion might be helpful as a workaround.
Reply 16 of 16, by Repo Man11
I've been slacking on this, easy to put it off because I've never used gerber files to order a PCB. And now I don't have to because someone is now selling the PCBs on Ebay. Of course I'll still have to order the components and do the soldering once I get them, but it's step in the right direction. One step closer to having a K6-3+ @ 400 MHz on my PCChips M507.
