Reply 20 of 3355, by Gemini000
- l33t
wrote:Hm. Something seems wrong with this ep. Although the ads play fine, the actual video stops playing for a long time while buffering after 27 seconds and stops altogether after 2 minutes or so, just after the Tandy section begins... All the other eps play fine and my connection should be able to handle it just fine (at 120Mbps).
I've checked and it's loading perfectly fine.
A glitch probably happened when you were trying to watch it last. Clear your browser cache and try again and you should be fine. If not, maybe you need to update your Flash player or use a different browser? As far as I can tell, the new filler episode loads and plays back flawlessly and no one else has mentioned any problems yet.
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
