HiRes/Widescreen Patch for Mech Warrior 3
First post, by teleguy
EDIT: I made the current state of the Widescreen mod ( v5) available for testing purposes:
EDIT2: File got deleted from the server. Here's the new link:
EDIT3: Reuploaded again:
http://s000.tinyupload.com/index.php?file_id= … 479823980438934
mirror: http://www.fastshare.org/download/Mech3_Wides … _HiRes__Mod.rar
mirror: http://workupload.com/file/dqgNsBT
mirror: http://www.mediafire.com/file/bl3napf9w23fqhw … s__Mod.rar/file
Alt Tab Fix
1440x1080 (4:3) Resolution patch by gerwin
1440x1080 (4:3) exe with resized Hud
This is a patch for Mech Warrior 3 to allow setting higher resolutions without making the game crash when pressing Esc.
As always USE AT YOUR OWN RISK!
Mech3HiRes_v1.zip
4.31 KiB
4086 downloads
285.21 KiB
1600x1200
Known issues:
-Clicking on "Options" in the Pause Menu still crashes the game
-1152 x 864 resolution is broken
Patch for upgrading MechWarrior3 to version 1.2 available at
http://www.moddb.com/games/mechwarrior-3/down … 2-english-patch
http://www.mechwarriorsunited.com/downloads.html.
Reply 1 of 75, by teleguy
Here's a quick and dirty patch with working Options menu.
The downside is that the menus will look a "bit" uglier. 😊
When you go to options from the Pause Menu for the first time some buttons will be missing, just go back to the previous menu by pressing Esc then click on options again.
I didn't have time to test everything so there might be other issues.
Mech3HiRes_v2.zip
4 KiB
988 downloads
Edit: Clicking on Options still makes the game crash at 1280x1024, all other resolutions seem to be fine.
Reply 2 of 75, by teleguy
Found a way to insert custom resolutions. Even widescreen is possible. However Mech3 is pretty picky about what resolutions it accepts, so far I haven't determined the logic behind this. Also the Hud doesn't scale properly.
1440x900
268.67 KiB
1680x1050
332.13 KiB
Edit: Widescreen patch.
Mech3_HiRes4.zip
4.37 KiB
1343 downloads
1152 x 864 replaced with 1440 x 900 and 1280 x 1024 replaced with 1680 x 1050
Reply 4 of 75, by teleguy
beatcracker wrote:
Is there any way to go beyond 1600x1200? Would be nice to run it at any arbitarty resolution.
I couldn't get any of the resolution bigger than 1600x1200 that I tried to work but that doesn't mean there aren't any.
In case anyone wants to give it a try here's a howto:
You need Ollydebug
http://www.ollydbg.de/version2.html
and the Windows Calculator.
Launch Ollydbg and open Mech3.exe
Click on View->Executable Modules and select Mech3.exe (it should be right at the top)
Select the "CPU -Main thread" Window and scroll to the top
Rightclick in the Window and use
Search for->Command to find mov ecx, 640h
If you scroll up a little bit should see this
161.83 KiB
That's a list of all resolutions currently available in the game
Case 8 for instance shows 1152x864 in hex form
360 (hex) = 864 (decimal)
480 (hex) = 1152 (decimal)
Each resolution is listed 3 times
You can easily convert decimal and hex values with your Windows Calculator. Press Alt+3 to switch to programmer view, with "Dec" at the left selected enter a decimal value and click on "Hex" to convert to hex.
For example if you want to replace 1152x864 with 1440x900 first convert 1440 and 900 to hex form.
900 = 384 (hex)
1440 = 5A0 (hex)
Then rightclick on MOV EDX,360 ->Assemble to replace it with MOV EDX,384
and then replace
MOV ECX,480 with MOV ECX,5A0
You have to do this 3 times each.
After that do a search for MOV EAX,480 and MOV EAX,360 to replace those as well.
227.22 KiB
To finalize the changes do another rightclick and select Edit->Copy all modifications to executable.
A new window will open. Rightclick on it and choose Save File... .
Reply 5 of 75, by teleguy
WIP
    771.6 KiB
    635.99 KiB
Reply 6 of 75, by teleguy
WIP
1280x720
123.5 KiB
1600x900
165.14 KiB
1920x1080
207.51 KiB
2560x1440
298.31 KiB
Reply 7 of 75, by teleguy
WIP
1440x900
141.28 KiB
1680x1050
170.39 KiB
1920x1200
218.58 KiB
Reply 10 of 75, by teleguy
All image attachments on vogons.org are temporarily disabled.
In order to properly display the HUD reader.zbd has to be edited. Since I couldn't find the official Mechwarrior 3 mod tools that are needed to do that anywhere on the net someone else helped me with that.
This is what we completed thus far:
http://s000.tinyupload.com/?file_id=98686211436986162560
We're still trying to find a way to change the FOV.
Reply 13 of 75, by iwanPlays
teleguy, thank you so much!
Gameplay video at 1920x1080 60fps:
https://youtu.be/cldiX4BG7F8
I initially didn't realize the newest version was in the first post, so I was trying to go the Ollydebug way to modify case 9 into 1920x1080. The result was broken. 😀
Will you try to scale videos, mission and menu screens as well or is that a losing battle?
Reply 14 of 75, by teleguy
I don't want to do anything about the menus, videos etc. Those are hardcoded to be 640x480, not selectable like the 3D mode resolution, so would probably be a lot harder to change.
The menus should already be fullscreen though, albeit still at 640x480, not in a corner like in your video.
Reply 15 of 75, by iwanPlays
They are fullscreen. It's just the way OBS records them when I do a 1080p screen capture. I'm just glad it works at all. 😀
Reply 16 of 75, by Night Thastus
Hey all!
I installed this high-res patch by moving the contents of the 16:9 folder into my MW3 folder and over-writing the two files that conflicted.
However, when I attempt to run the Mechwarrior 3 launcher, it says the Mech3.exe wasn't found. How do I fix this? I'd love to run above the native resolution!
Reply 17 of 75, by teleguy
Night Thastus wrote:
Hey all!
Is Mech3.exe inside the game folder?
Edit: Antivirus tools sometimes block or delete new files. Can you try copying those files with your antivirus disabled temporarily?
Reply 18 of 75, by Night Thastus
Yep! Actually, it fixed itself!
I have no idea how. I set the launcher to run as administrator and set it in Win7 compatability mode, and it worked. However, I disabled these settings, and it STILL worked. So no idea why.
Regardless, this is fantastic! I love this high-res patch!
However, quick question. When in 1920x1080, I notice that the UI is much smaller. I'm fine with that.
Is that a good way to know that it's working? I don't notice a ton of difference yet, but I've yet to play a lot yet.
