- Code: Select all
case 0x30: /*DIV AL,b*/
src16 = AX;
if (dst) tempw = src16 / dst;
if (dst && !(tempw & 0xff00))
AH = src16 % dst;
AL = (src16 / dst) &0xff;
flags_rebuild();
flags |= 0x8D5; /*Not a Cyrix*/
else
x86_int(0);
return 1;
CLOCK_CYCLES(is486 ? 16 : 14);
src16 = AX;
AH = src16 % dst;
flags_rebuild();
else
x86_int(0);
return 1;
case 0x30: /*DIV AX,w*/
templ = (DX << 16) | AX;
if (dst) templ2 = templ / dst;
if (dst && !(templ2 & 0xffff0000))
DX = templ % dst;
AX = (templ / dst) & 0xffff;
setznp16(AX); /*Not a Cyrix*/
else
// fatal("DIVw BY 0 %04X:%04X %i\n",cs>>4,pc,ins);
x86_int(0);
return 1;
CLOCK_CYCLES(is486 ? 24 : 22);
DX = templ % dst;
else
x86_int(0);
return 1;
case 0x30: /*DIV EAX,l*/
if (divl(dst))
return 1;
setznp32(EAX); /*Not a Cyrix*/
CLOCK_CYCLES((is486) ? 40 : 38);
break;
if (divl(dst))
return 1;
break;
Edit: and here
- Code: Select all
static int opENTER_l(uint32_t fetchdat)
uint16_t offset = getwordf();
int count = (fetchdat >> 16) & 0xff; cpu_state.pc++;
uint32_t tempEBP = EBP, tempESP = ESP, frame_ptr;
PUSH_L(EBP); if (cpu_state.abrt) return 1;
frame_ptr = ESP;
if (count > 0)
while (--count)
uint32_t templ;
EBP -= 4;
templ = readmeml(ss, EBP);
if (cpu_state.abrt) { ESP = tempESP; EBP = tempEBP; return 1; }
PUSH_L(templ);
CLOCK_CYCLES(3);
PUSH_L(frame_ptr);
CLOCK_CYCLES(3);
EBP = frame_ptr;
if (stack32) ESP -= offset;
else SP -= offset;
CLOCK_CYCLES((is486) ? 14 : 10);
return 0;
