Peixoto's patches for a few old games
Reply 240 of 893, by Alkimical
Hi Peixoto, thank you for fix the Resident Evil 1 cutscene, but the game crashes with new update. The game crashes when is running a cutscen, more or less 5 seconds from the beginning.
Reply 241 of 893, by Ruby_of_Blue
Hello, your patch works great in fullscreen, however I can't seem to run the game properly in windowed mode. The problem is, I'm trying to play Resident Evil 2 SourceNext version. However, the inventory lags like crazy in fullscreen mode, and works fine in windowed mode, even without your patch. When I press the key to change the game to windowed mode (F8), it stretches the game like crazy to where I can't see much of anything. But again, the inventory stops lagging when in windowed mode. Is there any way I can run RE2 SourceNext in windowed mode while still using your patch?
Reply 242 of 893, by Redgrave
Peixoto wrote:
Start Help.exe […]
Redgrave wrote:
Hi there, […]
Hi there,
First off I do want to thank you for your time and effort towards the selection of games here. Sadly though, I must add to the growing amount of derp in this thread and make my own inquiry...
I just bought Slave Zero off the general recommendations towards the game + how much better the game becomes after your patch. But I do not know how to apply your patch? I downloaded the Direct3D patch first and did the necessary things with that, but when it comes to your work I'm left at a loss. The patches folder from your .zip includes only 4 games, none of which are Slave Zero.
Provide me with the insight from the master himself, would you?
Start Help.exe
Find the Slave Zero entry
select it
Click the start button
Ah.
Now I return with a follow-up - Now that I have done this, when the game launches it crashes soon after. Don't even get to the menu or anything before this happens, and this occurs only after your patch has been applied. I can DL and run the d3d launcher just fine without, but naturally I'd like to utilize your adjustments as well. Any suggestions?
Reply 243 of 893, by Peixoto
Redgrave wrote:
Peixoto wrote:
Start Help.exe […]
Redgrave wrote:
Hi there, […]
Hi there,
Start Help.exe
select it
Ah.
Can you guys please post your contents of your error.log file ?
Are you using windows XP? Please post your error.log file
Try adding one of these two lines on the Resident Evil 2 -Sourcenext.ini file:
NEFS=True or
DMWM=True
and tell me if it works. It may cause FMVs to stop working, if it does, don't despair: this bug can probably be fixed
Reply 244 of 893, by Ruby_of_Blue
NEFS=True or
DMWM=True
and tell me if it works. It may cause FMVs to stop working, if it does, don't despair: this bug can probably be fixed[/quote]
Yo, thanks for the solutions. NEFS successfully stops the inventory from lagging, however it breaks the FMVs like you said, and also breaks the save screen to where it doesn't display the save data; can still operate it, but it's just blank. DMWM gives with the Direct X error when starting up the game. Any way I can get the FMVs working again?
Reply 245 of 893, by Ruby_of_Blue
Ruby_of_Blue wrote:
Are you using windows XP? Please post your error.log file […]
NEFS=True or
DMWM=True
Yo, thanks for the solutions. I'm running Windows 8.1. NEFS successfully stops the inventory from lagging, however it breaks the FMVs like you said, and also breaks the save screen to where it doesn't display the save data; can still operate it, but it's just blank. DMWM gives the Direct X error when starting up the game. Any way I can get the FMVs working again?
Reply 246 of 893, by Alkimical
Here is my error.log :
Peixotos's patch remote settings:
32bit: 1
AF: 1
args: /blaster
blaster: 1
CompatLayer: Win95
Controller: A=1;B=2;X=3;Y=4;LEFT_SHOULDER=5;RIGHT_SHOULDER=6;bLeftTrigger=7;bRightTrigger=7;Start=8;Back=9;LEFT_THUMB=10;RIGHT_THUMB=11;deadzone=0.240000;
d3D: 1
D3D_Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0325250.inf_amd64_f15289543c93a82a\aticfx32.dll
DSR: 1
error_log: C:\Users\Justin Steve\Documents\Programas\Peixoto\error.log
FMVScale: 2.25
FrameTime: 40.0
HD: 1
injector_dir: C:\Users\Justin Steve\Documents\Programas\Peixoto
max_4x3_res: 1360x1024
mods: C:\Users\Justin Steve\Documents\Games\ResidentEvil\mods\Jill-DirectorsCut;C:\Users\Justin Steve\Documents\Games\ResidentEvil\mods\RE1 BETA MOD
modspath: C:\Users\Justin Steve\Documents\Games\ResidentEvil\mods
Mydocs: C:\Users\Justin Steve\Documents
os_version: 10.000000
resolutions_list: 640x480 720x480 720x576 800x600 1024x768 1280x720 1280x768 1280x800 1280x960 1280x1024 1360x768 1360x1024 1366x768 1440x900 1600x900 1680x1050 1920x1080
script: Scripts\Resident Evil.ahk
script_hwnd: 0x4057c
target: C:\Program Files (x86)\RESIDENT EVIL\NEWEUR.EXE
target_dir: C:\Program Files (x86)\RESIDENT EVIL
target_name: NEWEUR.EXE
Textswap: samples=4;thumbnail=256;path=C:\Users\Justin Steve\Documents\Games\ResidentEvil\Textures;Next=PgUp;Prev=PgDn;dump=Home;Switch=End;color_switch=Delete;nopopins=;Quick=Shift;
CreateProcessA Hook: 0
CreateProcessW Hook: 0
Succeeded to create the DirectInput Interfaces
Succeeded to create the DirectInput8 Interfaces
Succeeded to hook IDirectInputDeviceW::GetDeviceState
Succeeded to hook IDirectInputDevice8W::GetDeviceState
Desktop 1920x1080
Direct3D user mode driver implemented in C:\WINDOWS\System32\DriverStore\FileRepository\c0325250.inf_amd64_f15289543c93a82a\aticfx32.dll
OpenAdapter Hook 0
DDraw.dll : C:\WINDOWS\SYSTEM32\DDRAW.dll
DirectDrawCreate Hook: 0
Succeeded to create DirectDraw
Succeeded to create Direct3D
Succeeded to hook IDirectDraw2::CreateSurface
Succeeded to hook IDirectDraw::CreateSurface
Succeeded to hook IDirectDrawSurface::restore
Succeeded to hook IDirect3DDevice::EndScene
Succeeded to hook IDirectDrawSurface::Blt
Succeeded to hook IDirectDrawSurface::Lock
Succeeded to hook IDirectDrawSurface::UnLock
Succeeded to hook IDirect3DTexture2::GetHandle
Succeeded to hook IDirect3DTexture2::Release
Succeeded to hook IDirect3DTexture2::Load
Succeeded to hook IDirect3DDevice2::SetRenderState
Succeeded to hook IDirect3DTexture::Load
Succeeded to hook IDirect3DTexture::GetHandle
Succeeded to hook IDirect3DTexture::Release
Succeeded to hook IDirectDraw::EnumDisplayModes
Succeeded to hook IDirectDraw::SetDisplayMode
Succeeded to hook IDirectDraw2::SetDisplayMode
Succeeded to hook IDirect3DViewport::SetViewPort
Succeeded to hook IDirect3DViewport::Clear
Succeeded to hook IDirect3DDevice::Execute
Succeeded to hook IDirectDrawSurface::flip
Succeeded to hook IDirectDraw::GetDisplayMode
Succeeded to hook IDirectDrawSurface::QueryInterface
Succeeded to hook IDirectDrawSurface::GetPixelFormat
Succeeded to hook IDirectDrawSurface::GetSurfaceDesc
Succeeded to hook IDirectDrawSurface::GetDC
Succeeded to hook IDirectDrawSurface::ReleaseDC
Succeeded to hook IDirectDrawSurface::SetPalette
Succeeded to hook IDirectDrawPalette::SetEntries
Succeeded to hook IDirectDrawPalette::GetEntries
Succeeded to unhook IDirectDrawSurface::Lock
Succeeded to unhook IDirectDrawSurface::UnLock
Succeeded to hook IDirectDrawSurface::Bltfast
Succeeded to hook IDirectDraw::SetCooperativeLevel
Succeeded to hook IDirectDraw2::SetCooperativeLevel
DrawDibDraw Hook : 0 <- 0 means no error
Succeeded to unhook IDirectDraw2::SetDisplayMode
Succeeded to hook IDirectDrawSurface::lock
Succeeded to hook IDirectDrawSurface::Unlock
Zbuffer depth 32
Failed to create surface 2147500033: 71 147456 1920 1080
Failed to create a 32 bit Zbuffer 2147500033:
Reply 247 of 893, by Redgrave
!Textswap: samples=4;thumbnail=256;path=C:\Users\Gerb\Documents\Games\d3d_SlaveZero\Textures;Next=[;Prev=];dump=home;Switch=end;color_switch=del;nopopins=True;Quick=Shift;
#compatlayer: WinXPSp2
32bit: 1
CompatLayer: HIGHDPIAWARE
d3D: 3
d3D_Driver: aticfx32.dll
DSR: 1
error_log: C:\Users\Gerb\Desktop\Peixoto\error.log
gamma: 1
HD: 1
Hideborder: 1
injector_dir: C:\Users\Gerb\Desktop\Peixoto
ManageTextures: 1
max_4x3_res: 1024x768
Mydocs: C:\Users\Gerb\Documents
os_version: 6.100000
resolutions_list: 640x480 720x480 720x576 800x600 1024x768 1280x720 1280x768 1360x768
script_hwnd: 0xe07d6
target: C:\Program Files (x86)\Steam\steamapps\common\Slave Zero\d3d_SlaveZero.exe
target_dir: C:\Program Files (x86)\Steam\steamapps\common\Slave Zero
target_name: d3d_SlaveZero.exe
Desktop 1360x768
Direct3D user mode driver implemented in aticfx32.dll
OpenAdapter Hook 0
Succeeded to hook IDirectDraw4::CreateSurface
Succeeded to hook IDirectDrawSurface4::restore
Succeeded to hook IDirect3DDevice3::EndScene
Succeeded to hook IDirect3D3::CreateDevice
Succeeded to hook IDirectDrawSurface4::QueryInterface
Succeeded to hook IDirectDrawSurface4::Lock
Succeeded to hook IDirectDrawSurface4::Unlock
Succeeded to hook IDirectDrawSurface4::Bltfast
Succeeded to hook IDirectDrawSurface4::Release
Succeeded to hook IDirectDrawSurface4::GetAttachedSurface
Succeeded to hook IDirectDrawSurface4::SetColorKey
Succeeded to hook IDirectDraw4::SetDisplayMode
Succeeded to hook IDirectDraw4::EnumDisplayModes
Succeeded to hook IDirect3DViewport3::SetViewPort2
Succeeded to hook IDirect3DViewport3::Clear
Succeeded to hook IDirect3DViewport3::Clear2
Succeeded to hook IDirectDrawSurface4::flip
Succeeded to hook IDirectDrawSurface4::GetSurfaceDesc
Succeeded to unhook IDirectDrawSurface4::bltfast
Succeeded to hook IDirect3DViewport3::TransformVertices
Succeeded to hook IDirect3DDevice3::DrawPrimitive
Succeeded to hook IDirect3DDevice3::DrawIndexedPrimitive
Succeeded to hook IDirect3DDevice3::DrawPrimitiveVB
Succeeded to hook IDirectDraw4::SetCooperativeLevel
Succeeded to hook IDirectDrawSurface4::GetPixelFormat
Succeeded to hook IDirectDrawSurface4::lock
Succeeded to hook IDirectDrawSurface4::blt
Reply 248 of 893, by Peixoto
NEFS=True or
DMWM=True
No, but i can fix it, just need the error log 1st
Alkimical wrote:
Here is my error.log : […]
32bit: 1
AF: 1
args: /blaster
blaster: 1
CompatLayer: Win95
d3D: 1
DSR: 1
FMVScale: 2.25
FrameTime: 40.0
HD: 1
Desktop 1920x1080
OpenAdapter Hook 0
Zbuffer depth 32
OK then, sorry but I will just make the FMV scale thing optional. While not impossible, its hard to fix bugs i can't reproduce
Redgrave wrote:
Peixotos's patch remote settings: !Textswap: samples=4;thumbnail=256;path=C:\Users\Gerb\Documents\Games\d3d_SlaveZero\Textures; […]
32bit: 1
d3D: 3
DSR: 1
gamma: 1
HD: 1
Hideborder: 1
ManageTextures: 1
Desktop 1360x768
OpenAdapter Hook 0
You have an old version, try the current one and enable WinXp compatibly (in the help.exe program page for the game)
Reply 249 of 893, by Ruby_of_Blue
32bit: 1
compatlayer: WIN98
Controller: A=1;B=2;X=3;Y=4;LEFT_SHOULDER=5;RIGHT_SHOULDER=6;bLeftTrigger=3;bRightTrigger=8;Start=8;Back=9;LEFT_THUMB=10;RIGHT_THUMB=11;deadzone=0.200000;
d3D: 2
D3D_Driver: nvd3dum.dll
dshow: 1.2
error_log: C:\Users\Cal\Desktop\Peixoto\error.log
gamespeed: 1.0
HD: 1
hideBorder: 1
injector_dir: C:\Users\Cal\Desktop\Peixoto
max_4x3_res: 1600x1200
modspath: C:\Users\Cal\Documents\Games\ResidentEvil2\mods
Mydocs: C:\Users\Cal\Documents
NEFS: 1
os_version: 6.300000
resolutions_list: 1920x1080 640x480 720x480 720x576 800x600 1024x768 1152x864 1176x664 1280x720 1280x768 1280x800 1280x960 1280x1024 1360x768 1366x768 1600x900 1600x1024 1600x1200 1680x1050 1768x992 1440x900 1024x576
s_cmptlr: Win98
script: Scripts\Resident Evil 2.ahk
script_hwnd: 0x2b0c4a
singlecore: 1
target: C:\Program Files (x86)\Capcom\BIOHAZARD 2 PC\RE2.EXE
target_dir: C:\Program Files (x86)\Capcom\BIOHAZARD 2 PC
target_name: RE2.EXE
Textswap: samples=4;thumbnail=256;Next=PgUp;Prev=PgDn;dump=Home;Switch=End;color_switch=Delete;path=C:\Users\Cal\Documents\Games\ResidentEvil2\SourceNext\Textures;nopopins=False;Quick=shift;
Succedeed to create the DirectShow interfaces
Succeeded to hook IVideoWindow::SetWindowPosition
Succeeded to hook IMediaControl::Run
Desktop 1920x1080
Direct3D user mode driver implemented in nvd3dum.dll
OpenAdapter Hook 0
Succeeded to hook IDirect3DDevice2::EndScene
Succeeded to hook IDirect3D2::CreateDevice
Succeeded to hook IDirect3DViewport2::SetViewPort2
Succeeded to hook IDirect3DViewport2::Clear
Succeeded to hook IDirect3DDevice2::DrawPrimitive
Succeeded to hook IDirectDrawSurface::GetAttachedSurface
Succeeded to hook IVideoWindow::put_Visible
TimeGetTime hook error: 0
Releasing Clipper 1
Releasing Clipper 0
Reply 251 of 893, by tarcisiorm
Hello, I had seen on PCWikiGaming that I could play Tomb Raider Last Revelation and Chronicles in 2160p with this patch, but it's not working. The game works well in 1080p, but it crashes in 2160p. Is it possible to play TRC in 2160p? It's a problem with my computer? Thanks
Reply 252 of 893, by Peixoto
Ruby_of_Blue wrote:
Download the newest update, there is a new option to fix the slow inventory
Try to run setup (hold shift), make sure the game is set to fullscreen, try different settings on the patch. If nothing helps try to create a trace file with API trace. There are a few post from myself in this topic explaining how to do so
Alkimical wrote:
This is what happens:
https://youtu.be/GeA2R84P_nk
Download the new version and leave the FMV scale at 1. The patch will behave as it did before that option was added. Small FMVs, but no crashes
Reply 253 of 893, by CoolGamer
Peixoto,
I have a new game request. 😀 Please take a look at "Time Commando" windows CD version (directx) whenever you have some free time. That game can benefit from xbox controller support, custom installer for 64bit systems and unblurried upscaling (no anti-aliasing). The game also has some color pallete problems on new OSs. "Time Commando" was made by the same team that made the Little Big Adventure series.
Thanks.
Reply 254 of 893, by Ruby_of_Blue
Awesome. The newest patch worked. Is there any way you can patch in a skip function for the cutscenes of RE2 Sourcenext? I know there's a mod for that, but I can't seem to get it to work.
Reply 255 of 893, by Peixoto
CoolGamer wrote:
Peixoto,
Thanks.
Sure, noted. It might just work if you crate a new ini file like this:
D3D=1
HD=True
args=whateverthegamexpects
It doesn't work for me either. I'll see what i can do
Reply 256 of 893, by Ruby_of_Blue
I'm having another issue in Resident Evil 2 SourceNext where some FMVs don't play, and the game goes completely mute after skipping them. (you can skip FMVs but not in game cutscenes).
Reply 257 of 893, by curseofnight
I really love these patches man! You're the best! I only have one question: Is it possible to set a preferred resolution in a games .ini in the Scripts folder? I can't play any games in my monitors native resolution without lag and constantly resizing the desktop resolution is annoying.
I tried adding
Height=800
Width=600
to onimusha's .ini file but it didn't seem to work. In fact it seemed to play worse than setting my desktop resolution to 800x600.
So is there an alternative? If not it's kool. I'm happy just be playing these games again.
Thank you for your time.
Edited once because mixed up height/width...
Reply 259 of 893, by Peixoto
curseofnight wrote:
I really love these patches man! You're the best! I only have one question: Is it possible to set a preferred resolution in a ga […]
I tried adding
Height=800
Width=600
curseofnight wrote:
Ignore what I said above about adding that line to the .ini making the game run slower. It didn't, it just simply ignores it I think. Sorry.
Resolution can't be changed, how old is your computer ?
Which FMVs, can you upload a save ?
