TheFast Version 1.04
                         Screen Display Speed Up Utility […]
                              COPYRIGHT (C) 1986,87
                  TheSoft Programming Services and Ian E. Davis
               All rights reserved by TheSoft Programming Services
        TheFast is a utility designed to do one thing; speed up the video
        display.   It  has  its  roots from a program  call  Zeno,  which
        unfortunately  doesn't work on the Tandy 1000.   I therefore  set
        out   to write my own solution to the problem of speeding up  the
        screen,  with  this  the  end result.
        TheFast  should be compatible with most any computer or  program,
        but obviously I can't claim it'll run everywhere.   Try it, if it
        works  your  screen writes will be between 200% to  500%  faster.
        The actual speed up depends on the application, and only benefits
        those  programs that use the Bios.  Programs with internal  video
        routines or those that directly access the screen  (ie:  PC-Write
        or  TheDraw)  won't be helped.   However they are  probably  fast
        enough already.
        TheFast  uses around 380 bytes of memory and works by eliminating
        any wait for video retrace.   On some color screens it may  cause
        snow.   Snow is harmless, but if you find it annoying TheFast can
        easily be removed.
        To load TheFast, just type THEFAST from the DOS prompt.  A notice
        will appearing indicating TheFast is installed.  TheFast can only
        be installed once, so you don't have to worry about it "stacking"
        itself  (such as Zeno does).   Stacking is where a  program  will
        allow  itself  to  be  installed  multiple  times.    This  could
        dramatically slow down performance if done.
        To  remove TheFast,  type THEFAST /K at the DOS prompt.   Spacing
        and  case  are unimportant.   Make certain you have  removed  all
        memory resident programs loaded after  TheFast.   Otherwise,  you
        will be left with a memory "hole" which might confuse Dos.
        TheFast                                                    Page 1
        TheFast Program History:
        v1.00  10/19/86  -  Initial Release.
        v1.01  11/16/86  -  Corrected glitch when writing to 40 column
                            screen.
        v1.02  02/19/87  -  Screen writes made faster by about 20%.
        v1.03  05/08/87  -  Routines used to detect presence of TheFast
                            revised.
        v1.04  05/30/87  -  Screen writes faster by about 2 to 4%.   Also
                            fixed minor glitch with new detection code.
        That is all there is to it.   If you find TheFast to be useful, a
        contribution of $5 or any amount would be greatly appreciated and
        would  help  towards the development of more  quality  shareware.
        Please send any checks and/or comments to:
        c/o Ian Davis
        1929 Whitecliff Court
        Walnut Creek, Ca, 94596
        Thanks!
        TheFast                                                    Page 2
