First post, by DosFreak
- l33t++
http://www.patches-scrolls.de/vampire_bloodlines.php
List of Changes: (+) annotes changes for Plus Pack only. […]
List of Changes:
(+) annotes changes for Plus Pack only.v5.6 03.09.2008
+Made Jack remove .38 to fix exploit and repaired broken Isaac logs.
+Decreased crossbows criminal level and fixed Sin Bin state reload.
+Fixed broken Empire hotel card printer usage and made it plus only.
+Restored first dot Domination options for Tremere during dialogue.
+Added overlooked humanity losses and restored sheet music of basic.
+Disabled true sight for Vick, Killer, Cathayan and Blood Guardian.
+Made Romero train up to Firearms 4 and Beckett up to scholarship 3.
+Increased xp gain on freeing Ash and delivering Imalia's magazine.
Added a few Shin Guntos to sewer hunters and improved end fade out.
Adjusted double Ithaca reload sound and added several drop sounds.
Repaired Barabus quest re-update and a wrong Zhao died quest state.
Corrected faulty Isaac lip-synchro and several minor text details.
Added sound to Kiki cutscene and fixed Hollywood bus stop map typo.
Removed a talk icon in diner and corrected lg firearms book value.
Made player get a look at Gimble's hand and fixed some map details.
BSPEdit updated to edit several prop stats, thanks to RobinHood70.
Fixed dialogue issues for Ming, VV, Trip, Boris, Vandal and Damsel.
Made unfinished Regent's plague quest fail in case you betray him.
Fixed ghouling quest not updating and improved Bertram's quest log.
Added Vandal gesture for females and fade out at the tutorial end.
Resolved bug when entering the Fu Syndicate while being obfuscated.
Prevented continuing E's quest after you failed it by killing him.
Fixed dialogue bugs of Skelter, Arthur, blueblood, clerk and Venus.
Added a missing light switch and missing door sound to King's Way.
Removed reference to Ricky at Glaze and made upstairs guards fight.
Repaired several cut off dialogue lines and a few lip-synch issue.
Moved Jack down to Skelter and improved Tin Can Bill's expressions.
Included 64bit install and memory tools, thanks to Iain Patterson.
Removed buggy SM haven board and Mercurio's note after you met him.
Moved Ash song from Empire hotel to the unfinished museum diorama.
Added default 1.2 map and python files to tools, thanks to Offkorn.
Restored katanas to Tongs and removed the one at Fu Syndicate.
Turned hospital into Elysium area during your encounter with Pisha.
Fixed dialogues for Jack, Mercurio, Regent, Razor and taxi driver.
Changed three history humanity penalties to avoid humanity of zero.
Lowered surf computer difficulty and added a Gargoyle quest state.
Made Tawni laptop reflect mission and fixed Zygaena and Yukie bugs.
Stopped Maria and Victor from dropping invitations they don't own.
Added inspection nodes to some trapdoors in the Giovanni crypt map.
