BASSMIDI Soundfont MIDI Synthesiser Driver for Windows XP/Vista/7
Schedules and announcements about program releases.
Re: BASSMIDI Soundfont MIDI Synthesiser Driver for Windows XP/Vista/7
Postby kode54 » 2016-1-24 @ 06:18
I can attempt to remove the external audio API calls from the driver and use BASS's own sound output method, which I can also combine with their BASSWASAPI driver, as an option.
The real problem is that I do all of my Windows development with a remote machine now, as I primarily run OS X on my iMac and MacBook Pro machines. I still have my previous Windows desktop, but it is devoid of any development software at this time.
User avatar
kode54
Postby kode54 » 2016-1-24 @ 08:58
Try the latest update.
User avatar
kode54
Postby HunterZ » 2016-1-24 @ 18:05
Seems to be working for me, although I didn't test the previous version in Windows 10.
User avatar
HunterZ
Postby autoexecdotbat » 2016-1-29 @ 20:15
hello, I am having a problem with basmidi, when using it the midi volume is very quiet, almost inaudible. this is affecting mainly the 7th level games (tested with great word adventure)
"911, call wiliam shatner!"
-stinky from great word adventure 1994
autoexecdotbat
Postby Tarvis » 2016-1-30 @ 17:46
Latest update did the trick, many thanks!
Tarvis
Postby autoexecdotbat » 2016-1-30 @ 19:56
thanks, I'm going to update it.
autoexecdotbat
Postby Tarvis » 2016-1-31 @ 19:28
On second thought, the new version seems to have trouble loading samples, there's about a 50% chance that all instruments except for percussion will become the #0 Grand Piano sample, even if loaded or changed after a reset.
I noticed that when this happens, a very small segment of the beginning of the correct instrument will play (probably .05 seconds or less) and then cut off, and then all further notes will play as the piano instrument.
There's also a tiny pause when new instruments are introduced (whether they all load as piano or not, in fact it might be the same length of time as the above phenomenon), no matter if the preload setting is used, where previous versions did not.
Tarvis
Postby kode54 » 2016-2-01 @ 01:56
Then kindly enable sample pre-loading, and you won't experience any caching issues.
User avatar
kode54
Postby Tarvis » 2016-2-01 @ 02:33
The issues, especially where all instruments are piano happens regardless of that setting. Any soundfont, any application. Any time on device open or after a reset there is about a 50% or 25% chance all instruments will load as piano, other than percussion. I don't mean when there's a reset while a song playing, I mean at any playback is started, even if instruments change well later.
If the instruments all load as piano, the loading delay happens regardless of the preload setting.
This has only started in this latest version, it has never happened before. I'll try ensuring it installs completely from scratch just in case to be sure.
Tarvis
Postby kode54 » 2016-2-01 @ 03:02
Well, I have yet to reproduce that issue. I haven't changed anything with how BASSMIDI itself works, other than updating it to a newer version, and that update took place several months ago.
User avatar
kode54
Postby Tarvis » 2016-2-01 @ 03:14
Is there any kind of debug log I can enable or send that might help find the issue?
In the mean time I'll try using the BASS dlls from the previous version
Tarvis
Postby RoyBatty » 2016-2-02 @ 17:23
kode54: could you make your download page for bassmidi clearer, it's a huge mess of links and redirects and cannot even find the download.
User avatar
RoyBatty
Postby kode54 » 2016-2-02 @ 20:44
Blame the page designer, who wasn't me. I adopted the page from mudlord, who had received the design from Rich "Weeds" Nagel.
I'll see if I can make it more obvious.
User avatar
kode54
Postby rfnagel » 2016-2-03 @ 01:14
<grin> :)
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
User avatar
rfnagel
Location: Out in the woods of Crystal River, Florida USA
Postby RoyBatty » 2016-2-03 @ 06:22
Thanks, I was getting miffed getting looped around constantly. :)
User avatar
RoyBatty
Postby HunterZ » 2016-2-05 @ 20:06
I think I eventually formed a muscle memory of where the download link is ;)
User avatar
HunterZ
Postby Tarvis » 2016-2-05 @ 20:33
The "sometimes all samples are piano" issue also happens on my laptop.
I see in the source the latest version alters some code involving critical sections. I can only assume that since the behavior is inconsistent there is some kind of race condition or threading issue going on. That's were I'd look.
Tarvis
Postby kode54 » 2016-2-06 @ 02:25
Try downloading it and updating again.
User avatar
kode54
Postby Tarvis » 2016-2-06 @ 19:25
That did the trick for sure. Many thanks once again.
Tarvis
Postby Enverex » 2016-2-09 @ 22:04
BASSMIDI seems to work generally fine for me (as I use it for MIDI in Foobar) but I do have one issue - I can't open the configuration program. If I try (even as admin) nothing happens. I've uninstalled and reinstalled with no change. Double clicking the executable seems to do something for a moment but nothing ever appears or opens.
EDIT: Forgot to mention, this is Windows 10.
User avatar
Enverex
PreviousNext
Return to Release Announcements
Who is online
Users browsing this forum: Zanin and 1 guest
