First post, by DosFreak
- l33t++
Vmware Workstation 8
http://www.vmware.com/products/workstation/new.html
https://www.vmware.com/support/pubs/ws_pubs.html
https://www.vmware.com/support/ws80/doc/relea … on_Requirements
When you install Workstation, the installer performs checks to make sure the host system has a processor that meets the followin […]
When you install Workstation, the installer performs checks to make sure the host system has a processor that meets the following requirements. You cannot install Workstation if the host system does not meet these requirements.
64-bit x86 CPU
LAHF/SAHF support in long mode
You can use CPU-Z or a similar utility to determine if the host system CPU is 64-bit capable. CPU-Z shows EM64T (Intel) or AMD64 (AMD) if the processor is 64-bit capable.
Vmware Fusion 4
