Reply 60 of 117, by RaVeN-05
- Oldbie
P.S. Dont forget read my previous post =).
I think Pyl designed for Voodoo 1 card , so anyone can test it? The next idea i want to try DOS32A extender for this game.
from cfg: (perf = performance change +- , inc = increase)
fog_distance (no perf, by logic less fog more fps?)
resolution (no perf, lowering more fps?)
textures quality (0=max 4=min) (no perf, should be 4 more fps, but no again)
textures facture on(def) (no perf, should increase fps by turning off, its detailed textures)
shadows on (default) (no perf, should inc fps if turned off)
*aim (no perf, turned off should inc fps, what a good option on is onscreen crosshair)
*lens effect (PERF!!!, turned off is increase fps in case if you use sniper scope, if you change to night vision it again drops fps, it turns off glass distortion, fps drops in animations when you turn it on and off)
Also the game seems don't have any 3dfx msdos variables like we use in bat files before start game.
SET SST_... VALUE
SET FX_... VALUE
SET BUILD_... VALUE
Placing glide2x.ovl from Voodoo1 drivers doenot give anything, game don't want start.
P.S. Well dos32a failed here, or i use it incorectly , last version fail, first ever failed , i not tried between versions http://download.narechk.net/
