Pył, Pyl, Dust English language version
Reply 80 of 92, by Kerr Avon
Thanks for uploading these. But how do you get it to run, please?
I've downloaded and installed Pyl from the Pyl CD image (called Pyl.iso, size 606,162,944 bytes), then downloaded both of your .7z files, un-archived them into the Pyl folder, and run the qemu.bat file, and the game doesn't start. Neither does the game start if I run s.exe
I've put the .ISO file into the folder, and even mounted the ISO file (which became drive R:), but neither qemu.bat nor s.exe start the game.
Here's the file listing of the folder:
Directory of D:\Pyl
15/05/2020 22:21 <DIR> .
15/05/2020 22:21 <DIR> ..
15/05/2020 21:38 <DIR> DATA
15/05/2020 21:38 <DIR> LEVEL
15/05/2020 21:38 <DIR> PLAYER
01/02/2020 01:32 262,144 bios-256k.bin
14/05/2020 15:16 2,149,580,800 boot.vdi
14/05/2020 22:14 15,578 dgvoodoo.conf
17/04/2020 18:55 352,256 dgVoodooCpl.exe
15/05/2020 21:39 265,396 DOS4GW.EXE
01/02/2020 01:32 240,128 efi-e1000.rom
13/05/2020 20:23 93 glide.cfg
17/04/2020 19:09 146,432 glide.dll
17/04/2020 19:09 145,920 glide2x.dll
17/04/2020 19:09 148,480 glide3x.dll
01/02/2020 01:32 9,216 kvmvapic.bin
09/04/2020 13:16 32,768 libffi-7.dll
06/04/2020 14:13 82,944 libgcc_s_seh-1.dll
10/04/2020 16:43 1,560,576 libgio-2.0-0.dll
10/04/2020 16:43 1,228,800 libglib-2.0-0.dll
10/04/2020 16:43 24,064 libgmodule-2.0-0.dll
10/04/2020 16:43 333,824 libgobject-2.0-0.dll
13/05/2019 07:18 1,055,522 libiconv-2.dll
14/05/2019 11:23 135,218 libintl-8.dll
09/03/2020 17:26 283,648 libpcre-1.dll
20/04/2020 19:21 681,472 libpixman-1-0.dll
06/04/2020 14:13 20,480 libssp-0.dll
25/04/2020 15:02 53,760 libwinpthread-1.dll
15/05/2020 21:39 1,011,472 MFC42.DLL
15/05/2020 21:39 267,536 Msvcrt.dll
15/05/2020 21:39 1,633,038 PYL.EXE
15/05/2020 21:39 1,078 PYL.ICO
15/05/2020 21:39 131 pyl.ini
26/01/2013 17:49 606,162,944 Pyl.iso
15/05/2020 21:39 770,048 PYLINSTL.EXE
15/05/2020 21:39 40,960 PYLSETUP.EXE
14/05/2020 15:53 3,014 qemu.bat
12/05/2020 20:18 9,113,088 s.exe
13/04/2020 07:54 1,549,312 SDL2.dll
15/05/2020 22:21 0 t.txt
01/02/2020 01:32 39,424 vgabios-stdvga.bin
22/05/2019 13:06 93,720 zlib1.dll
37 File(s) 2,777,345,284 bytes
5 Dir(s) 16,483,233,792 bytes free
The t.txt file is just the directory listing, obtained by me typing dir /o > t.txt, if you're wondering what it was doing there.
Thanks for any help.
Reply 82 of 92, by Kerr Avon
robertmo wrote on 2020-05-16, 02:03:
you must install
Intel® Hardware Accelerated Execution Manager (Intel® HAXM)
from here https://github.com/intel/haxm
OK, I'll do that tomorrow, thanks mate.
Reply 83 of 92, by Kerr Avon
Nope, still not working. First of all, should I put the .ISO in the PYl folder, or mount the ISO as a disc in a drive, or (mount the ISO as a disc in a driver and) install Pyl via it's own installer to the Pyl directory using MagicDisc or similar?
I've currently done all three, , but the game won't run.
Running qemu.bat (with the ISO mounted as R:) writes the following text to the screen (recorded here by qemu.bat > t2.txt)
D:\Pyl>SET QEMU_AUDIO_DRV=sdl
D:\Pyl>s.exe boot.vdi -cdrom a: -soundhw sb16,adlib -accel hax
s.exe: -cdrom a:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom b: -soundhw sb16,adlib -accel hax
s.exe: -cdrom b:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom c: -soundhw sb16,adlib -accel hax
s.exe: -cdrom c:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom d: -soundhw sb16,adlib -accel hax
s.exe: -cdrom d:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom e: -soundhw sb16,adlib -accel hax
Failed to open the HAX device!
Open HAX device failed
Failed to get Hax capability:6u
No accelerator found.
s.exe: -accel hax: failed to initialize hax: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom f: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom g: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom h: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom i: -soundhw sb16,adlib -accel hax
s.exe: -cdrom i:: Could not refresh total sector count: Input/output error
D:\Pyl>s.exe boot.vdi -cdrom j: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom k: -soundhw sb16,adlib -accel hax
s.exe: -cdrom k:: Could not refresh total sector count: Input/output error
D:\Pyl>s.exe boot.vdi -cdrom l: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom m: -soundhw sb16,adlib -accel hax
s.exe: -cdrom m:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom n: -soundhw sb16,adlib -accel hax
s.exe: -cdrom n:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom o: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom p: -soundhw sb16,adlib -accel hax
s.exe: -cdrom p:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom q: -soundhw sb16,adlib -accel hax
s.exe: -cdrom q:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom r: -soundhw sb16,adlib -accel hax
D:\Pyl>s.exe boot.vdi -cdrom s: -soundhw sb16,adlib -accel hax
s.exe: -cdrom s:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom t: -soundhw sb16,adlib -accel hax
s.exe: -cdrom t:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom u: -soundhw sb16,adlib -accel hax
s.exe: -cdrom u:: Could not read image for determining its format: Input/output
error
D:\Pyl>s.exe boot.vdi -cdrom v: -soundhw sb16,adlib -accel hax
s.exe: -cdrom v:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom w: -soundhw sb16,adlib -accel hax
s.exe: -cdrom w:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom x: -soundhw sb16,adlib -accel hax
s.exe: -cdrom x:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom y: -soundhw sb16,adlib -accel hax
s.exe: -cdrom y:: Could not read image for determining its format: Input/output
error
D:\Pyl>s.exe boot.vdi -cdrom z: -soundhw sb16,adlib -accel hax
s.exe: -cdrom z:: Could not open device: Invalid argument
D:\Pyl>s.exe boot.vdi -cdrom a: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom b: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom c: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom d: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom e: -soundhw sb16,adlib -accel whpx
s.exe: -accel whpx: Could not load library WinHvPlatform.dll.
s.exe: -accel whpx: failed to initialize whpx: Function not implemented
D:\Pyl>s.exe boot.vdi -cdrom f: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom g: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom h: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom i: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom j: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom k: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom l: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom m: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom n: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom o: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom p: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom q: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom r: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom s: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom t: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom u: -soundhw sb16,adlib -accel whpx
error
D:\Pyl>s.exe boot.vdi -cdrom v: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom w: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom x: -soundhw sb16,adlib -accel whpx
D:\Pyl>s.exe boot.vdi -cdrom y: -soundhw sb16,adlib -accel whpx
error
D:\Pyl>s.exe boot.vdi -cdrom z: -soundhw sb16,adlib -accel whpx
D:\Pyl>pause
Press any key to continue . . .
(The pause, of course, was added by me to the batch file). I don't think the failure of the game to run is down to the .ISO or it's contents, because I've tried to cover all three ways of using it, but maybe something due to:
Reply 87 of 92, by Kerr Avon
That's probably it then. I'm trying to run it on my laptop (it's been too nice recently to not spend time in my garden, one of the few good things about the present state of the world), which is an old HP Pavilion g6-1331sa with a 1.6 GHZ AMD Quad-Core A8-3520M CPU (according to (https://support.hp.com/gb-en/document/c03125593#AbT0).
Reply 89 of 92, by Kerr Avon
robertmo wrote on 2020-05-18, 14:47:
you must use intel desktop
You mean it needs an Intel CPU and probably a desktop, not laptop, PC? Fair enough, and thanks for all the help. It's much appreciated.
Reply 90 of 92, by kjliew
Kerr Avon wrote on 2020-05-18, 20:40:
Only if you want to use Intel HAXM accelerator for obvious reason.
AMD CPUs have no viable accelerators for QEMU on Windows, other than Windows 10 x64 when Microsoft finally provides vendor agnostic user-space APIs for virtualization. However, AMD was more generous with CPU features. Unlike Intel, AMD did not leverage CPU virtualization for market segmentation, so every AMD CPUs had AMD-V when the feature was marketed while Intel reserved it for higher priced segment in the Core series. Celerons and Pentiums did not get Intel-VT in the beginning.
