Doom 'MBF' for DOS, Maintenance release 2.04
Schedules and announcements about program releases.
Re: Doom 'MBF' for DOS, Maintenance release 2.04
Postby gerwin » 2018-8-02 @ 11:57
I found ALL of them within 30 seconds using google search.
User avatar
gerwin
Postby SilverMiner » 2018-8-02 @ 12:49
And I didn't... Freaky Russian searching systems...
Nope, I did... I found this
https://virtuallyfun.com/wordpress/2010 ... or-ms-dos/
But all the links are dead.
So... where I can get the packs?
The Boggy Region megawad released: https://www.doomworld.com/idgames/?id=19210
User avatar
SilverMiner
Postby gerwin » 2018-8-02 @ 19:54
Google each single filename+extension separately. Every first result page has a working link of some kind.
User avatar
gerwin
Postby SilverMiner » 2018-8-03 @ 07:23
Gerwin, I had set up the env, run _make but I have some errors:
cc1.exe: Invalid option 'tune = i486'
cc1.exe: Invalid option 'Wno-pointer-sign'
make.exe: *** [obj/doomdef.o] Error 1
User avatar
SilverMiner
Postby gerwin » 2018-8-03 @ 18:31
The first error is because the makefile in the MBF204 source package was still set up for a newer DJGPP/GCC. I just reuploaded the source with an adjusted makefile + _make.bat.
The last error may be more severe. I don't know why you get that.
I just checked it quickly: DosBox SVN r3970 with the specified compiler actually compiles doom MBF 2.04. Eventhough DosBox is not intended to be used for such.
User avatar
gerwin
Postby SilverMiner » 2018-8-03 @ 18:35
Succesfully compiled, thanks!
User avatar
SilverMiner
Postby gerwin » 2018-8-03 @ 18:47
I see in your screenshot: folder DJGPP instead of DJGPP97?
User avatar
gerwin
Postby SilverMiner » 2018-8-03 @ 18:49
In the older _make.bat and makefile it's DJGPP folder
Now I have a cool source port to play doom on my gran's computer...
User avatar
SilverMiner
Postby gerwin » 2018-8-03 @ 18:59
SilverMiner wrote:Succesfully compiled, thanks!
Great! Good to hear that.
User avatar
gerwin
Postby SilverMiner » 2018-8-23 @ 11:35
Gerwin,
About modified Allegro: How did you do custom resources (doom titlepic, e1m1 midi and demon sight sound ) in setup?
Where I have to put them to do?
User avatar
SilverMiner
Postby gerwin » 2018-8-23 @ 22:52
These resources are in Allegro30\Setup\Setup.dat. Grabber.exe is a tool to modify Dat files with a user interface. It is in the Allegro30\Tools folder. Also there is Dat.exe which is a command line tool to make Dat files.
User avatar
gerwin
Postby SilverMiner » 2018-8-24 @ 11:13
Ok, thanks
User avatar
SilverMiner
Postby leileilol » 2018-8-26 @ 03:43
Unfortunately the recent versions including Doom2's SSG would hurt its chances of being recommended among the doom community as well as the archive...
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
DOSBox is not for running Windows 9x
SGL != Glide
User avatar
leileilol
Postby gerwin » 2018-8-26 @ 18:22
leileilol wrote:Unfortunately the recent versions including Doom2's SSG would hurt its chances of being recommended among the doom community as well as the archive...
It was there from the start. But I agree it should go. Instead I will try to add a script to build SSG.wad from Doom2.wad.
User avatar
gerwin
Postby LABS » 2018-9-25 @ 11:58
Hello, does MFB support CD music playback?
User avatar
LABS
Postby gerwin » 2018-9-27 @ 22:02
Don't think so. Plenty of midi options though.
User avatar
gerwin
Postby appiah4 » 2018-9-28 @ 05:51
This is a pretty commendable effort, thank you gerwin. I tried it, but I think DOOM loses much of its charm in higher resolutions.
1989:A500|+512K|ACA500+|C1084S
1992:HIPPO-VL+|DX2-66|8M|GD5428|CT2290|S2
1995:PCI597-1|P133|32M|Trio64|V1|CT3980/2M
1998:S1573S|K6-2/400|64M|RagePro|V2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
2004:K8V-D|3700+|2G|X1950P|SB0350
User avatar
appiah4
Postby neozeed » 2018-12-15 @ 08:29
SilverMiner wrote:And I didn't... Freaky Russian searching systems...
You have to read the 404 pages!
Because of those automated 'virus scans' I've been de-platformed a few times so I have to hide stuff behind a 404 page & username / passwords. They auto-generate so you have to read the page!
User avatar
neozeed
Postby neozeed » 2018-12-15 @ 08:38
BlueSkullKey wrote:SilverMiner
Maybe some of this stuff will be interesting to you
https://sourceforge.net/p/crossdjgppv1/
https://sourceforge.net/p/crossdjgppv2/
https://sourceforge.net/projects/cdoom207/
crossdjgppv2 most likely. I had set that up originally to build MAME 0.1 and Allegro as many other build sets I had simply were too new for the ASM syntax of Allegro.
I'd written about it here:
https://virtuallyfun.com/wordpress/2018 ... dos-djgpp/
It was.. hours of fun :dead:
Also I've used it to build my lame / minimal changed doom:
https://sourceforge.net/p/crossdjgppv1/ ... ster/tree/
Although I haven't merged in all the x68000 changes, but I did get it to (mostly) compile with GCC 1.27, which is the first public versions support for the i386 with BSD syntax showed up! the only thing 'missing' is the m_fixed stuff.
User avatar
neozeed
Previous
Return to Release Announcements
Who is online
Users browsing this forum: No registered users and 2 guests
