First post, by x86++
Attached two replacement wav files** for Action Quake 2 v1.52. In the case where there are in-game errors related to these files, then copy the replacement files to AQ2 PAK1.PAK (under /sounds/weapons/). A tool that does PAK file handling is "pakscape".
The shellhit1.wav file may not be necessary if "shell casings" is turned off in autoexec.cfg.
** Original link to AQ2 sound packs:
http://www.oocities.org/timessquare/bunker/9606/downaq2.htm
    missing_sounds.zip
    16.42 KiB
    85 downloads
    aq2-152 wav file replacements
Reply 1 of 1, by x86++
Attached patch for AQ2 mod in action directory of the q2dos project. It decreases volume of eject shell sounds, modifications for more human-like bot behavior (from aq2-tng project), and removal of limping effect after taking leg damage since the bots don't seem to display this effect.
    action_bots.diff
    4.36 KiB
    58 downloads
    aq2-152 patch #1
