S3VBEFIX - PC\MS-DOS TSR fix for S3 VESA 2.0 video BIOS
Schedules and announcements about program releases.
Re: S3VBEFIX - PC\MS-DOS TSR fix for S3 VESA 2.0 video BIOS
Postby wbc » 2016-8-19 @ 18:26
After two months of silence... we are back with a new release ;)
Changes since 0.5.1:
  • some user interface fixes (help wasn't worked as intended and some strings were screwed up)
  • VESA function 0x1 fake memory size patcher fixes:
    • new video page number is limited to 127 (some LAME applications treat this field as signed byte, which if incorrect and sometimes can cause problems and crashes)
    • new video page number calc procedure now uses only 16 bit registers, therefore S3VBEFIX probably can run on 286 now (is someone uses S3 cards in 286 machines? :)
  • VESA function 0x6 new scanlines number patcher (fixes this and possibly other issues while using /M[x] key)
--wbcbz7
wbc
Postby keropi » 2016-8-19 @ 19:10
^ great, time to update :)
thanks for the release wbc!
User avatar
keropi
Postby keropi » 2017-7-19 @ 07:21
I tried v0.52 and naturally it added the 320x400 resolution I wanted for DN3D :) but I noticed it detected my 8MB Speedstar A55 as a 4MB card
is this normal ?
funny thing is that I had tested previous version and completely forgot about it, I even found some DN3D framerate notes I made ... I need a brain defrag :lol:
User avatar
keropi
Postby mrau » 2017-7-19 @ 21:26
i don't think it matters really, 4mb is enough for that game and mode anyway; also i think it's just bad detection, it was common back in the day and did not influence performance in any way;
mrau
Postby wbc » 2017-11-11 @ 15:54
keropi wrote:is this normal ?
probably not :)
Which amount of memory is reported by other VESA applications/Windows drivers? and AFAIK you are using that patched BIOS version or something else? :)
--wbcbz7
wbc
Previous
Return to Release Announcements
Who is online
Users browsing this forum: No registered users and 4 guests
