Reply 20 of 23, by havli
It is a problem for me... I want my games to run as intended with no extra effort. Testing so many GPUs is very time consuming as it is. Searching for some obscure hacks which might not even work properly is certainly not the right way for me.
Also I will use the same system for testing GTX 200, 400 series and HD 3000/4000/5000 series - all of which need win7 anyway to run at their full potential.
Reply 21 of 23, by Srandista
You still can run Steam under XP with some workarounds. But as you said, that could stop working any day, and then your results wouldn't be comparable between each other (XP vs. 7).
Socket 775 build - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon X800XT, ESS Solo-1, 80GB IDE HDD, Win 98/XP
Socket A build - ASRock K7S41GX, AMD Sempron 2200+, 512MB RAM, GeForce4 Ti4200, SB Live! 5.1, 4GB CF card, Gotek, Win 98
