First post, by hail-to-the-ryzen
Attached a patch and binary for D2X, a source port of Descent 2. It seems to work in Win95 under emulation. Included in the archive is also the SDL library dependency, brief instructions on compiling, and a batch file to start D2X at full screen and with the mlook option from DXX-Rebirth. User takes responsibility for any testing of contents.
Requires full version of Descent 2.
    d2x-11-29-04-mod.zip
    437.88 KiB
    94 downloads
    Descent 2 source port with patch (D2X)
Reply 1 of 3, by hail-to-the-ryzen
Attached a patch and binary for a more recent version of D2X which is dependent on the archived physfs library. User takes responsibility for any testing of contents.
    d2x-6-10-11-mod.zip
    495.91 KiB
    73 downloads
    Descent 2 source port with patch (ver 2)
Reply 2 of 3, by hail-to-the-ryzen
Attached updated archive with a fix to movie playback.
    d2x-6-10-11-mod-2.zip
    495.97 KiB
    75 downloads
    Descent 2 source port with patch (ver 2a)
Reply 3 of 3, by hail-to-the-ryzen
Attached two versions of D2X which include patches and documentation within their respective archives. Used emulation to test binaries. User takes responsibility for any testing of contents.
D2X-6-10-11-mod-3 is an update of the version attached to the above posts. Includes menu bug fixes. This version is for 8-bit color depth and is tested in Windows 95.
D2X-Rebirth-Retro is from a team who developed a "Retro" branch of the D2X-Rebirth source port. Patched and tested in Windows 95. Its assembly routines are not working with the current code base. Requires 16-bit color depth. Slower performance than the above version, but has enhancements and is expected to run stable in Windows. A good reference to compare against the D2X-6-10-11-mod-3 binary.
    d2x-rebirth-retro.zip
    616.48 KiB
    91 downloads
    D2X-Rebirth-Retro source port with patch
    d2x-6-10-11-mod-3.zip
    499.13 KiB
    102 downloads
    D2X source port with patch (ver 3)
