First post, by DosFreak
http://cemu.info/
# Cemu detailed changelog for 1.11.5 # Patreon release date: 2018-02-24 # Public release date: 2018-03-03 […]
general: Updated game profiles
general: Added more logging options and cleaned up logging menu a bit
general: Enabling online mode now requires all ccert/scert files
input: Added support for emulating Wiimote controllers using keyboard/usb-controllers (no native support yet!)
input: Reworked the input settings window to open a lot faster
coreinit: Fixed MEMAllocFromExpHeapEx not handling negative alignment correctly
coreinit: Fixed MEMGetAllocatableSizeForExpHeapEx sometimes returning the wrong size
coreinit: Added API MEMCreateUserHeapHandle(), OSCopyFromClipboard()
coreinit: Fixed a potential crash in FSReadFile/FSReadFileAsync when the specified length is zero
AX: Rewrote snd_core2 audio driver
AX: Added snd_core1 API AXGetMaxVoices(), AXSetVoiceSamplesAddr()
GX2: Reduced shader compile time and RAM usage for Nvidia GPUs
GX2: Added support for creating cube-map views into 2D array textures
GX2: Added support for more vertex attribute formats
swkbd: Added support for Unicode input + some minor tweaks
nlibcurl: Fixed a crash bug in curl_multi_perform
Make your games work offline
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
But can it run Zelda? 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by DosFreak
I've been playing Breath of the Wild for roughly 20hrs using the previous ver of Cemu. Occasionally there were brief pauses every so often but it didn't ruin the game.
Had an issue with videos only showing a green screen so had to disable the graphics pack but on this version haven't had that issue.
Haven't played the game much with this new ver only played about an hour yesterday.
6700k with Geforce 1080.
Reply 3 of 5, by Dominus
DOSBox Moderator
I might hav to use the other emulator, because I need a native OS X port...
