Fasttracker 2.10 & 2.11 for MS-DOS
Reply 60 of 67, by 8bitbubsy
SaxxonPike wrote on 2020-05-27, 14:08:
Thank you so much for updating FastTracker II! This was a very unexpected project. I recall learning how to use trackers in the late 90s with version 2.04. It was my introduction to music altogether. To see any updates since 2.09 is like a dream come true. I can't wait to return home and try this out.
You might want to check out my accurate FT2 clone for modern OSes too: https://16-bits.org/ft2.php
Reply 61 of 67, by digger
8bitbubsy wrote on 2018-11-07, 16:16:
Because it's not trivial to implement. We're talking low-level hardware interraction through x86 assembler here. I'm not the correct dude for implementing new big things like that.
Perhaps this could help: I've dusted off the source code of a simple WAV player for AC'97 sound devices as found in motherboards and laptops with Intel ICH, ICH0 and ICH2 southbridges. It was initially written and released by Jeff Leyda. I'm currently trying to improve it to support later ICHx revisions up to ICH7 as well.
It's DOS assembly code that's fairly easy to follow. It also helps that it's well documented.
Perhaps you could use it as a basis to add ICHx AC'97 support to Fast Tracker II for DOS as well?
See topic Re: Can anybody with AC'97 audio please help me test a DOS player? 😊
Or would adding support for new sound devices really be too herculean?
How about doing so through a more high-level API, such as VBE/AI, which works with int 10h calls and abstracts away all the tedious DMA stuff?
At any rate, thanks for continuing to support Fast Tracker II. Even though I'm not much of a composer, I remember playing with it back in the day and marvelling at the (for the time) fancy UI and smooth performance. It's one of the sleekest non-game DOS applications I've ever experienced.
Reply 62 of 67, by 8bitbubsy
That's way too much code to go through for supporting just some AC'97 devices, and FT2 is running in 16-bit protected mode. Implementing this wouldn't be trivial for someone like me, and unfortunately I'm not allowed to share the FT2 source code with other people.
Reply 63 of 67, by traffkin
8bitbubsy wrote on 2020-05-27, 18:47:
that's real pity, as i've found a guy who knows the subject very well and he could fix all the stuff and add a lot, for example acceptable midi implementation...
Reply 65 of 67, by 8bitbubsy
traffkin wrote on 2020-06-18, 16:02:
is there any chance to have a midi clock in/out on the FT2?.. would be just awesome...
Again, I don't really know MIDI nor the low-level MIDI stuff in FT2. I am not the right person to add these new low-level things. Sorry...
Reply 67 of 67, by 8bitbubsy
I'd like to try and fix it instead of removing the feature. Does anyone know in what FT2 version it stopped working when you select LPT1+LPT2 @ stereo? I can't test it myself because I have no PC with a second parallel port, thus selecting LPT2 or LPT1+LPT2 will just revert to LPT1.
If someone would like to find out for me, I'd be happy. Here's a collection of all the FT2 releases I have found so far: https://16-bits.org/ft2
(the only version I'm missing is FT2.02 (and possibly FT2.00) . If someone has it, let me know!)
