First post, by robertmo
- l33t++
Vulkan support.
Direct3D 12 support.
Vulkan support.
and forces me into 32bit world so be of any use T.T
wrote:and forces me into 32bit world so be of any use T.T
Hm? It seems to work fine for 64-bit.
if you compile on a 64 bit system and exclude 32bit binaries it would run 32bit software well?
wrote:if you compile on a 64 bit system and exclude 32bit binaries it would run 32bit software well?
If you build it yourself, you need to follow the guide. You build once for 32-bit and once for 64-bit, and then you combine the two prior to installing so that it can run both 32-bit as well as 64-bit Windows executables.
It would be easier to install it through your package manager though. Wine has a PPA for Ubuntu, I think.
