Reply 23 of 25, by ViTi95
MrFlibble wrote on 2020-06-26, 15:52:
Playing with the shareware 1.9 IWAD does not display the third episode's title for some reason on the episode selection screen.
I'll check into this, there are more bugs out there for sure.
Calvero wrote on 2020-06-28, 19:23:
Is Doom faster when it uses a chained hash table instead of linear search?
I haven't implemented it yet, but I think this should be a minor speedup, as the number of visplanes used ingame aren't that much (original WADs).
MAZter wrote on 2020-06-30, 02:35:
I confirm that on the laptop 486 DX2 50Mhz fps increased by 1.52 (from 17.62 to 19.20) using Dos Benchmark Pack config for faster PC.
Can you post your laptop specs? I'm analyzing which are the major bottlenecks in Doom depending of the hardware, so i can focus in those bottlenecks.
leileilol wrote on 2020-06-30, 08:37:
I'm assuming NukeYKT reverse-engineered their own DMX-like given their prior work on the Doom OPL3 Windows MIDI driver.
This port is using NukeYKT sound library from PCDoom-v2, i don't know if it's the original version, a reverse-engineered one or custom made. My idea it's to replace it complitely to a custom one, so the sound cache problems can be fixed and make the tickrate control internal instead of depending in the sound library.
Reply 24 of 25, by MAZter
ViTi95 wrote on 2020-07-02, 10:52:
CPU: 486 DX2 Mobile 50Mhz
Video: Yamaha 6388 (1Mb)
Memory: 20 Mb
Reply 25 of 25, by MAZter
Laptop with 486 DX4 75Mhz cpu, fps increased by 0.9fps (20.09 to 20.99)
specs:
cpu: Mobile 486 DX4 75Mhz
video: unknown, 1Mb
memory: 12Mb
Laptop with Pentium 75Mhz cpu, fps increased by 2.13fps (33.52 to 35.65)
specs:
cpu: Mobile Pentium 100 Mhz
video: Chips&Tech 65540 1Mb
memory: 24Mb
