First post, by vvbee
On GitHub: https://github.com/leikareipa/w95
Test app: https://tarpeeksihyvaesoft.com/experimental/w … t-app/#no-debug
A fully custom canvas-rasterized UI framework for building Win95-lookalike JavaScript apps. Integrates a software 3D renderer so you should be able to make some games too.
Currently in beta with various known issues. Expect many API changes.
I started this project a while ago to have something useless to work on here and there. I still don't have any use for it, so it's coming along well.
Reply 2 of 5, by vvbee
It's also possible to integrate DOSBox into the UI relatively seamlessly by painting a hole in the canvas with a transparent widget, composing it with the DOM element of jsdos underneath and doing some dynamic redirecting of mouse and keyboard events. The animation is from a year ago when I did a test implementation. The w95 UI now uses multiple canvases rather than one so this doesn't work directly, but probably can be adapted.
Reply 4 of 5, by vvbee
Proper DOSBox integration works more or less. Sort of pointless though. I guess you could build a web app with this that takes in a ZIP of a DOS game, displays the files in an explorer, and runs the exes in DOSBox, for what it's worth. A bit roundabout.
    197.44 KiB
Reply 5 of 5, by StriderTR
I have to echo.... this is cool!
I will be playing with this very soon. 😀
Thanks for posting!
Retro Blog: https://theclassicgeek.blogspot.com/
Archive: https://archive.org/details/@theclassicgeek/
3D Things: https://www.thingiverse.com/classicgeek/collections
