IBM APTIVA 2144-M63 BUILD - BIG UPGRADES
Reply 120 of 140, by Limpem
Señor Ventura wrote on 2021-07-13, 19:14:
KSHIRZA1 wrote on 2021-07-13, 10:15:
This is the reason I went with the overdrive cpu. 200 mmx no problem and easy install without fiddling around. Switch 66.6 fsb v […]
Señor Ventura wrote on 2021-07-12, 19:46:
My aptiva doesn't let me upgrade teh cpu until 200mhz MMX, only at 200mhz, without MMX.
I imagine it depends of the number of the build, right?, Where must i search to find the build of mine pc?.
This is the reason I went with the overdrive cpu. 200 mmx no problem and easy install without fiddling around. Switch 66.6 fsb via jumpers.
This was my info source and it lists machine types:
http://aptivasupport.com/uas/cpu/
Ah, yeah, i alreadyremember where the problem was: my motherboard doesn't have the jumper to modify the voltage.
By the way, What solution did you choose for the heatsink?, i'm thinking about an 8x8x5cm copper one, but i can't find one... ^^u
I used a startech fanp1003ld for my normal 233 MMX (You can still buy them new very easily).
They are a little large, but they cool very good for socket 7.
As KSHIRZA1 pointed out, the overdrive comes with it's own fan and heatsink.
Changing the voltage on the motherboard isn't a jumper setting, you actually need to change a component.
If you can send the partnumber of your motherboard, we can lookup what options are available for your system, but an overdrive will almost always work if you can get one.
430HX/P1 233MMX/64MB/S3VirgeDX,Voodoo1SLI(King Shaman)/AWE32
440BX/CelTualatin1400/512MB/Banshee, PowerVR PCX2/AWE64Gold
645DX/P4Northwood 3,5Ghz(Oc)/512MB/Voodoo5500/Vortex2
875P/P4EE 3,4Ghz/1GB/GeforceFX5950/Audigy2ZS
Z97/i3-4370/16GB/GeforceGTX960/X-Fi
Reply 121 of 140, by Señor Ventura
Limpem wrote on 2021-07-14, 07:38:
I used a startech fanp1003ld for my normal 233 MMX (You can still buy them new very easily). They are a little large, but they c […]
It fits... only 41mm, although i have just above (partially) the cd drive. I have only 5cm height in that part.
My motherboard doen't have the jumper to reduce the voltage to put in a pentium 200 mmx, i already looked at that. The max cpu i can have is an pentium 200mhz.
Reply 123 of 140, by buckeye
Immaculate condition as always! I'm sure it sounds great too.
Reply 125 of 140, by soupapes
Your machine looks awesome! Congrats.
- IBM Aptiva 2176/P166/Matrox Millenium 4Mb/Voodoo1 4Mb/48Mb/8Gb+8Gb SD-IDE/SB16/Win98SE
- 486 DX2 66/CL-GD5424/32mb/HD 600mb/Mozart601/Dos6.22+Win3.11
- P166MMX/S3VirgeDx/96Mb/8Gb SD-IDE/SB16/Win98SE
- P4 3GHz/FX5700/2Gb/HD 80Gb+160Gb/Win XP
Reply 126 of 140, by airs
I love your Aptiva, great build! Thank you for sharing with us 😀
Reply 127 of 140, by jadkins2222
Do you have an iso of the original 2144 m63 recovery disk. I have the same machine. My CD is scratched beyond repair my floppy works and trys to open the CD but fails half way thru writing the recovery.
I found a few online but the are in a foreign language.
Reply 128 of 140, by KSHIRZA1
jadkins2222 wrote on 2022-01-19, 04:07:
I’ll try to make one soon.
\\IBM Aptiva 2144 build\
My instagram @kshirza1
Reply 129 of 140, by EuphoriA
KSHIRZA1 wrote on 2022-02-03, 00:32:
Hi KSHIRZA1,
I also have IBM Aptiva 2144. My motherboard crashed in bios update. It is currently not opening. Since IBM flash files are specific, I cannot write this files with eprom programmer. Can you take the BIOS file image of your motherboard with UNIFLASH and send it to me?
Reply 130 of 140, by Señor Ventura
I have a question about your monitor... I have an G40 too, How do yo see the image at 800x600?.
In my case i can see the imagen goodly sharp at 640x480, but at 800x600 the picture is blurry, Does it something to do with the integrated VGA card? (i have not try with the dedicated VGA card yet).
Reply 131 of 140, by KSHIRZA1
I wanted a power station and the Kensington masterpiece has the perfect look. After some searching I found a brand new one to add to my Aptiva. Looks great!
Reply 132 of 140, by buckeye
Probably the cleanest IBM setup I've seen, what games you play on it?
Reply 134 of 140, by BitWrangler
I've got one of those MasterPiece units, mine is a bit more yellow and some switches seem glitchy though. Handy to stick under older-school monitors with no swivel though... well mine is, has a turntable under it.
Thanks for posting the box etc, given me the idea that the MOVs could be worn out in mine... I think they go flaky after too many big hits... so might not be the switches.
Reply 135 of 140, by Señor Ventura
KSHIRZA1 wrote on 2022-09-23, 16:49:
buckeye wrote on 2022-09-23, 13:25:
Thank you. Right now it’s been Star Wars dark forces. Just before that I tried to get through rise of the triads. Always return to sim city 2000.
What resolutions do you reach?.
I have the same ibm with the same monitor, and beyond 640x480 it becomes blurry.
Reply 136 of 140, by Paadam
What is the FRU of the L2 cache COAST modules? I have exactly the same Aptiva (two to be precise, tower version too, with exactly the same board).
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 138 of 140, by KSHIRZA1
Before the above mentioned sound card I finally have found a brand new set of the original speakers with matching power button (all I cared about). Once I unboxed them I didn’t expect the size difference. These are much bigger…
Reply 139 of 140, by chrismeyer6
That's a great find with those speakers. There a nice looking set and yes that's quite the size difference.
