Reply 741 of 913, by Duffman
I suppose I could try and port XP's ATAPI.sys driver back to 98SE by internalising all the code it imports from ntoskrnl and hal.
It's tedious though, and I'm not even sure it'll work. So I'm not all that motivated to try and do it.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 742 of 913, by divideBYzero
Forgive my possible ignorance in this, but is the 2k driver, being older, perhaps any less complex to work with? I only mention it because it seems to work well, and from a relatively simple thought process, it seems it could be less complex due to not having support for more modern hardware. I did check my 2k vs a XP install and the driver is different. The 2k driver is around 10kB less and dated as quite older so perhaps it would be less work to dig through?
Reply 744 of 913, by Duffman
@divideBYzero @Vridek
That's why I was thinking of internalising all the code that it gets from ntoskrnl and hal.
That way it won't have any dependency on the NT kernel and can just do everything it needs to do by itself.
But yeah, that's tedious.
CPU: Ryzen 9 5950X
Reply 745 of 913, by Vridek
I'm already quite desperate, today I made WeeCee revision 0.4. Unfortunately the BIOS does not see the SD card. I have rechecked the paths and everything is fine. Does anyone have any experience of what this could be? According to the schematic there should be nothing wrong. Thank you for any help.
Reply 746 of 913, by Paul_V
Vridek wrote on 2023-01-13, 23:30:
Did you follow the instructions sent you by ICOP?
If so you need to revert the change:
"Set “OnBoard IDE Operate Mode” to “Legacy IDE" SD Card
Reply 747 of 913, by Vridek
It's obviously not a BIOS setting. I set it up the same way as with version 0.3, which I have at home, and it works great. But version 0.4 refuses the SD Card. I still have the SOM304RD52VINE1. I've checked the paths, resistors and haven't found a problem. I kept with https://workspace.circuitmaker.com/Projects/D … /rasteri/weeCee including the revision of the components.
    653.09 KiB
Reply 748 of 913, by Mu0n
Vridek wrote on 2023-01-14, 13:48:
You've checked continuity from the SD card slot pins to the rest of the circuit, but have you checked continuity between the pins? Have you ruled out a tiny solder ball between pins that sits unseen under the component?
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
DOS Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 750 of 913, by NachtRave
Don't suppose anyone knows how to get the LAN working in WinMe? Have tried the 98 and 2k drivers and neither seems to work -- installs and reports a working device, but no internet. Anyone solve that one?
Reply 751 of 913, by Duffman
@Nachtrave
1st.
Use the windows 98 driver not the 2000 one.
2nd.
To check if Internet connectivity is actually working ping a DNS server e.g
ping 8.8.8.8
If you get a ping back then you do have internet, but I'd imagine Internet Explorer wouldn't work very well on the modern internet.
If you don't get a ping back then something has gone wrong and we'll need to take a closer look.
CPU: Ryzen 9 5950X
Reply 752 of 913, by Duffman
I've been using IDA disassembler to modify the code inside ESDI_506.PDR
But every time I go to test it, I get a Windows Protection Error.
Does anyone know why this happens?
Is there a way to skip this error?
CPU: Ryzen 9 5950X
Reply 753 of 913, by NachtRave
You put the wrong pulldowns and pullups in the spots you should had left disconnected. R10 and R19 should be NC, so you shouldn't have populated those.
Reply 754 of 913, by NachtRave
In other news we got mentioned by the 8 bit guy!!! https://t.co/WzBofewDf4 -- weeCee I sent him is going to get reviewed. 😄
Apparently people in the comments think it was rasteri who sent it in, although it was actually me. :3
Reply 755 of 913, by Vridek
NachtRave wrote on 2023-01-15, 21:41:
I made adjustments to the components according to revision 0.4. WeeCee is already running great.
Reply 756 of 913, by Vridek
NachtRave wrote on 2023-01-15, 21:43:
Great work 😉
Reply 757 of 913, by Vanessaira
Vridek wrote on 2023-01-15, 23:41:
Great work 😉
Hopefully positive things will come from the additional exposure.
V
An Analog Girl in a Digital World
Reply 758 of 913, by Duffman
Is there anyone here familiar with using the wdeb386 debugger?
I'd like to use it to trace through ESDI_506.PDR to find out why it fails on the WeeCee but I've never used it before.
I'll still go at it by trail and error, but some actual expertise would be greatly appreciated.
CPU: Ryzen 9 5950X
Reply 759 of 913, by Vridek
I got a new reply about ICOP
We found the IDE driver in Real mode under Win98 can't distinguish our IDE Controller. So, under Device Manager, we will see both Primary & Secondary IDE Controller with an exclamation mark, that means we can only run in PIO mode, and it make system very slow. In Win98, even if the BIOS is changed to IDE Compatible Enabled, there is still an exclamation mark in Win98, and even if we try to change to the Intel IDE Vendor ID & Device ID, it does not work.
I have tried to modify it by following the link below, but I still can't get Win98 to drive our IDE Controller with the correct IDE Driver.
The reason why DOS is fast is that our BIOS has “PCI Bus Master Enabled” enabled, and DOS will run DMA Mode according to the BIOS plan.
I'm already sent this issue to our bios team, and keep you updated.
