Reply 20 of 81, by Errius
Right, this takes care of parity calculations.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 21 of 81, by PC Hoarder Patrol
Irinikus wrote on 2023-06-12, 15:08:
I may end up going with ATI on this one, but I first need to receive the motherboard and confirm that it works! […]
This would be a journey, as I've pretty much always stuck to Nvidia!
Slotting one of these little cards upgrades the onboard SCSI to SCSI RAID: (A huge thanks to @PC Hoarder Patrol for sharing the details pertaining to this add-on card! 😀 )
A super cool option!!!
Nice 😀 - I got my ZCR card new, so may still have the support CD / disks if its of any interest
Reply 22 of 81, by Irinikus
My board arrived today and it's unfortunately damaged!
There are some deep scratches on the back of the board which have completely cut through quite a few traces:
There's also a missing decoupling cap:
All of this will have to be repaired before I apply power to the board in-order to test it! (How annoying!!!)
YouTube
Reply 23 of 81, by Irinikus
I have an avionic technician at work doing repair work on the damaged board, but as a precaution I've managed to purchase another, this time a brand new unused one! (I'm going to be spending a fair amount of money on this build, so I don't want a sketchy motherboard!)
The seller has two more boards for sale: (this ones's an example)
Mine is still sealed:
I also got these specs from the seller:
From these specs, it's apparent that neither of the two boards were actually rated for the 3GHz 4MB cache CPU!
So I'll end up installing two 2.4GHz 2MB cache CPU's in mine in order to remain within the original design spec for the board!
YouTube
Reply 24 of 81, by Irinikus
It appears that the highest I'm going to be able to go here is a 2.2GHz chip with 2MB L3: (As the 2.4GHz chip doesn't come with L3, but has the same TDP of 65W!)
YouTube
Reply 25 of 81, by Irinikus
The broken traces on the board have been repaired and covered in a layer of epoxy:
Seeing that I've ordered a brand new board, this one will serve as a spare.
YouTube
Reply 26 of 81, by TheOkMan
I have a Supermicro P4DCE+ with the newest bios it works with the 3ghz gallatin's. I put heatsinks on the vrm to keep it cool works great
Reply 27 of 81, by Irinikus
TheOkMan wrote on 2023-07-17, 17:08:
Thanks very much for the info! 😀
Can you maybe post a pic of your board showing your heatsink solution?
YouTube
Reply 28 of 81, by TheOkMan
I put some 20x20 aluminum heat sinks and a small fan. It's the heat sinks with the thermal tape it's not the best solution but it works
The attachment 20230717_134351.jpg is no longer available
Reply 29 of 81, by Irinikus
TheOkMan wrote on 2023-07-17, 17:48:
Thanks very much for the input!!! It's highly appreciated! 😀
YouTube
Reply 30 of 81, by Irinikus
Confirm you're running the 3GHz chip with 4MB cache?
YouTube
Reply 31 of 81, by TheOkMan
Yea
Reply 32 of 81, by Irinikus
Thanks very much! This is great news indeed! 😀
YouTube
Reply 33 of 81, by TheOkMan
Later this month I will see if a Potomac 8mb xeon will work in my supermicro x5dal-g
Reply 34 of 81, by Irinikus
The Supermicro x5dal-g also appears to be a pretty cool board! 😀 (It will be interesting to see the advantage that the 8MB cache offers!)
The 8X AGP slot's also a cool feature! (No GPU bottleneck)
My brand new Supermicro P4DCE+ arrived from Germany today! 😀
YouTube
Reply 35 of 81, by TheOkMan
I tested the ATI Radeon x1950 pro agp on the gallatin's
The attachment 20230719_005941.jpg is no longer available
The attachment 20230719_004406.jpg is no longer available
Reply 36 of 81, by Irinikus
TheOkMan wrote on 2023-07-19, 05:01:
I tested the ATI Radeon x1950 pro agp on the gallatin's 20230719_005941.jpg20230719_004406.jpg
Which motherboard were you using for this test?
YouTube
Reply 37 of 81, by TheOkMan
Supermicro P4DCE+ with 2gb of 800 40 rdram and a Radeon x1950 pro agp
Reply 38 of 81, by Irinikus
TheOkMan wrote on 2023-07-19, 15:42:
Cool! That's a pretty good score! 😀
YouTube
Reply 39 of 81, by Irinikus
Seeing that I've dumped my Dual Pentium Pro build for now. As it's way too unstable to waste any more of my time and more money on! (For now anyway) I'm looking to put this Pentium 4 system together, when I have some money available to purchase an InWin X-Frame 2 to serve as an AGP card flashing machine.
The attachment IMG_8455 copy.jpg is no longer available
It will be a good opportunity to showcase an RDRAM system featuring a Voodoo 5 5500 PCI card! (I have these things lying around, so I should put them to good use! if I can.)
Always allot of fun to be had setting up Windows XP Professional on a vintage PC!!!
The attachment IMG_8456 copy.jpg is no longer available
The attachment IMG_8458 copy.jpg is no longer available
Here is it with the second CPU installed:
The attachment IMG_8461 copy 2.jpg is no longer available
YouTube
