First post, by Bruno128
Transparent WinXP SP1 build with CCFL lights in style of year 2003 running DirectX 7-8 titles. Targeted games: 1999 – 2003.
Highlight parts:
  • AMD Athlon XP 3000+ with Thermaltake BigTyp 120
  • ABit NF7-S V2.0 with Thermalright SLI-IFX chipset cooler
  • Dual-channel 1GB OCZ Performance DDR PC3500
  • Asus V9950/128 (GeForce FX5900) with Zalman VF900
  • TerraTec SiXPack 5.1+ as DAC for Tos-Link passthrough from Nvidia SoundStorm primary output
  • Sunbeam Acrylic Case
  • Amarina CCFL 80mm
Misc parts:
  • HP DVD Writer 400i
  • Alps DF354H FDD
  • Realtek 3.5 bay card reader
  • Corsair SF450 Gold with ATX bracket
  • Crucial BX500
Now playing:
The Dig: 1995 VLB 486
Arcanum: 2003 Acrylic build
SBEMU compatibility reports list | Navigation thread
Reply 1 of 15, by H3nrik V!
Absolutely love that case!
Reply 2 of 15, by DerBaum
H3nrik V! wrote on 2024-01-13, 21:37:
Yes the Sharkoon Showcase always was pretty cool to look at.
FCKGW-RHQQ2
Reply 3 of 15, by Nexxen
I missed yours. Looks beautiful! 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 4 of 15, by giantclam
I've still got one of those cases as well...
Reply 5 of 15, by xelizor
Hey, that's a really nice system!
One question, why woukd you need a secondary sound cad if your motherboard already has spdif out? 🤔
Cheers
Reply 6 of 15, by Bruno128
xelizor wrote on 2024-01-22, 12:15:
I want to enjoy NVIDIA SoundStorm Dolby audio in my headphones but I also want to avoid onboard Realtek codec analog circuitry as well as bulky external audio hardware. Terratec SiXPack 5.1+ (CS4297A) acts as a software DAC: it receives digital signal via TOS-Link looped back from the motherboard and outputs it to 3.5 headphones. This works automatically on startup and there is no playback latency.
Thanks for the nice reactions everyone!
Now playing:
Reply 7 of 15, by Shadzilla
Very very cool build!
Are the fans still available to buy anywhere? I tried to get a blue cold cathode for a build recently but I was sad to find they basically don't exist anymore, all replaced by LED (which to be fair is much easier, safer, and cheaper anyway).
Reply 9 of 15, by xelizor
Bruno128 wrote on 2024-01-22, 14:09:
I want to enjoy NVIDIA SoundStorm Dolby audio in my headphones but I also want to avoid onboard Realtek codec analog circuitry a […]
Oh now I get it, thanks for the clarification!
Cheers
Reply 10 of 15, by H3nrik V!
Bruno128 wrote on 2024-01-13, 19:30:
[*]ABit NF7-S V2.0 with Thermalright SLI-IFX chipset cooler
Is that the heatpipes standing right above the GPU?
Reply 11 of 15, by nd22
Nice build, always a pleasure to see an Abit board put to work! I understand from the screen shots that you have an Athlon XP 3000 FSB 400 CPU?
Reply 12 of 15, by Bruno128
psychofox wrote on 2024-01-22, 16:45:
Xoxide
Probably sold under different names in different countries.
I made a PDF from assembly manual that came with it:
Sunbeam Acrylic Manual.pdf
Sunbeam Acrylic case P/N list
  • 4x 3015-AC-01. Base feet
  • 4x 3010-AC-03. Long cover plate
  • 4x 3010-AC-04. Small cover plate
  • 8x 3014-AC-01. Corner blocks
  • 2x 3013-AC-07. Interior
  • 1x 3013-AC-03. Top
  • 1x 3013-AC-04. Bottom
  • 1x 3013-AC-05. Right panel
  • 1x 3013-AC-06. Left panel
  • 1x 3013-AC-02. Back
  • 1x 3013-AC-01. Front
  • 2x 7017-AC-01. Cotton gloves
  • 24x 5003-AC-02. 5.0mm panel screws
  • 2x 5003-AC-04. Speaker assembly
  • 1x 2013-AC-01. Speaker assembly
  • 1x 5038-AC-01. I/O shield plate
  • 1x 7019-AC-01. Aluminum backplate
  • 11x 5002-AC-18. Backplate screws
  • 7x 7018-AC-01. PCI slot plates
  • 7x 5002-AC-16. PCI mount screws
  • 2x 5005-AC-04. Switch PCB standoffs
  • 2x 5003-AC-15. Switch and LED assembly
  • 1x 2003-AC-05. Switch and LED assembly
  • 8x 5003-AC-01. 8.0mm panel screws no.2
  • 9x 5005-AC-03. MB standoffs coarse threaded
  • 9x 5002-AC-17. MB mount screws
  • 12x 5003-AC-03. Face plate pins
  • 4x 5002-AC-12. Long PSU mount screws
  • 8x 5002-AC-13. Long fan screws
  • 12x 5002-AC-14. Short fan screws
  • 20x 5005-AC-01. HDD standoffs coarse threaded
  • 8x 5005-AC-02. Floppy drive standoffs fine threaded
  • 44x 5002-AC-11. Drive mount screws
Now playing:
Reply 13 of 15, by Bruno128
H3nrik V! wrote on 2024-01-23, 20:48:
Yes. It clears between video card and CPU cooler thanks to heatpipes L-shape.
Now playing:
Reply 14 of 15, by matze79
Must be hell to keep this clean, if frequently used!
Looks nice!
Reply 15 of 15, by Bruno128
nd22 wrote on 2024-01-25, 10:26:
Thanks, yes it's AXDA3000DKV4E part.
Now playing:
