First post, by Skyscraper
I bought an Abit BH6 as soon as it was released in 1998.
I had a pII-233 that I overclocked to 350 mhz with a massive 40cm deskfan pushing air into the case.
A few months later I changed the CPU to a Celeron 300A that I overclocked to 504 mhz without needing extreme measures like the desk fan.
My original Abit BH6 is probably gone, at least I cant find it and the Celeron 300A I last saw a couple of years ago but now I cant find it either.
No worries I still have the case I used back in 1998 and I recently bought a "new" Abit BH6 and a Celeron 333.
Since this is a build for old Windows games that would run to slow on the the Leviathans K6-2(3) the Celeron probably wont cut it.
Back in 1998 I let a then newly released Voodoo Banshee handle the graphics, that card is now in the Leviathan.
To get the build more in line with what I need I will use an overclocked Katmai 600 and a GeForce3 ti200.
Also included in the build is: My AWE64 Gold that I used back in 1998, 768mb sdram and a 40gb Samsung hdd.
Some images
All stuff in one picture
The components.
The Celeron and the ATI Rage 128pro in the image will be benchmarked for reference.
One of the best motherboards with one of the best chipsets of all time.
The Celeron 333 and the Katmai 600 with an improvised cooler mount
ATI Rage 128 pro
GeForce 3 ti200
The AWE64 Gold, this card has been moved around latley but its in this build to stay.
Some sort of Samsung 40GB HDD
A cheap PSU.
At least it has a powerful 5v rail.
Pioneer slot in dvd from 1999
Test bench
Posting without issues
Then I was going to update the bios so It would be able to detect the 40gb hdd.
I downloaded the bios image from some trustworthy abit fan site.
The included instructions from Abit read as follows "The BH6 uses 2M EEPRAM, please use the AWDFLASH.EXE 6.22 version (or newer) for upgrades."
I did use that version and the bios update froze midway through. Why cant these things work as advertised? Could it be the Millenium boot disk?
Lucky enough the board still booted from the floppy and I flashed the new bios with uniflash.
This is the second time uniflash saves my ass in less than a week.
Success!
I have already installed Windows 98 and Im done with the benching.
Now I just have to convert some BMP screenshots to JPG 😀
Reply 1 of 17, by swaaye
I had a BH6 back in '98 too. Ran a Klamath, a Deschutes and then a Katmai. My board developed cold boot problems though (I often had to use reset to get it going). Ever had that problem with your boards?
In '99, I replaced the BH6 with a BF6 because of that cold boot issue and because I wanted the beefier power regulation and superior Softmenu options. I still have the BF6 today. I have eyed BH6 boards on ebay occasionally though!
Reply 2 of 17, by Nahkri
Will windows 98se be able to handle the 768mb of ram? i read that everything above 512 is cousing problems.
Reply 4 of 17, by Skyscraper
Nahkri wrote:
Will windows 98se be able to handle the 768mb of ram? i read that everything above 512 is cousing problems .
I did the maxfilecache hack so it works perfectly 😀
I have never had any cold boot issues with the BH6 but with the MSI MS6119 BX board I often had to restart 3 times before it acually posted.
Some more pics
The hardware is now dressed 😀
Reply 5 of 17, by Skyscraper
Its time for an update and an upgrade!
This is the Windos 98 system I use for DX7 and DX8 games.
The Katmai @ 672 mhz was not that fast in games from 2001 - 2002 so I upgraded it to a Coppermine 850 @ 952 mhz.
It is possible that this system will get an even faster Coppermine or perhaps a modified Tualatin in the future.
I also upgraded the Video Card from a GF3 TI200 to a GF4 TI4600.
The new video card and two Coppermine P3 1000(133) on slotkets for future use.
The BH6 system with the new Video Card and a Coppermine P3 850 on a slotket.
Reply 6 of 17, by GL1zdA
I like the classic In Win Q500 tower. One of my favourite cases from that time (another being the Enlight EN-7230).
getquake.gif | InfoWorld/PC Magazine Indices
Reply 7 of 17, by Skyscraper
I also like the case. Its nice that you can mount the hdd and floppy drive in the top of the case.
I should get it cleaned up and install the missing drive bay covers.
And that other case you mentioned... 😀
I had one of those aswell for one of my other systems.
I just found the case in my cold storage and used it for building a fast DOS 6.22 + Windows 3.11 system.
Reply 8 of 17, by chinny22
Man that case is massive!!! but that's the kind of style I Like, not boring but just a few nice simple lines how they put the FDD next to the power button is a nice space saver as well (not that space is a problem here)
I like the build but wouldn't a newer sound card be a better option for windows games, What are you mostly playing on it?
Reply 9 of 17, by nforce4max
Have you gotten any retro bright yet? Makes the yellowed plastics appear white again.
Reply 10 of 17, by sliderider
Spray paint would look cooler.
Reply 11 of 17, by Skyscraper
The AWE64 is there to avoid problems. This motherboard has no PCI 133/4 divider.
As you see I am using an ISA network card aswell.
The only important thing using PCI is the motherboards hdd controller. As long as I use a HDD that can handle 44 mhz PCI I can use the 133 mhz setting if I have to.
Its not an issue with the Coppermine 850 but with a Tualatin 1400(133) or a Coppermine 1133.
I think I have to get another hdd though of I want to use the 133 mhz setting. I tried it with one of the Coppermine P3 1000(133).
Stability was OK but it took double the time to boot Windows and that is not a good sign. Perhaps it can be solved by switching to PIO mode.
No retro bright yet. I think I will try the retro bright before I do something as drastic as using spray paint 😀
Reply 13 of 17, by Skyscraper
Mau1wurf1977 wrote:
Why overclock such a nicely restored system. Just leave it at stock and enjoy it!
If we are talking about the 850@952 I can only answer that with: Why not? The extra performance do some good and its not like a Coppermine P3 850 cares if it runs at 850 or 952.
I can still enjoy my system when its a little bit faster 😀 I could use the 124 mhz fsb setting but I do not because I like to stay at default voltage and keep the PCI-bus closer to spec.
If we are talking about the 133 mhz fsb setting with a 133 mhz fsb CPU then it is only the PCI and AGP that gets overclocked, the CPU is at its default speed.
I do not think I will use a 133 mhz fsb CPU in this system permanently but its nice to have the option for benching if not for anything else.
Reply 14 of 17, by Forevermore
Whilst I know the the BH6 was a decent overclocker, why bother with the risk of damaging it? Those boards are excruciatingly difficult to find & are expensive.
Id be more comfortable with getting a 900, 1000 or 1100 Coppermine.
I agree with mau1wurf on this one. But it is your system 😀
So many combinations to make, so few cases to put them in.
Reply 15 of 17, by Skyscraper
I think we will have to agree on disagreeing 😀
I have never seen any hardware damaged by overclocking exept maybe Socket-A CPUs but those burn if you look at them the wrong way.
I have also experienced that overclocked Video Cards that run very hot will not overclock as well after a few years but I think that mostly is because of caps degrading.
Heat can kill caps on the motherboard as well but heat is not an issue with this system at all.
Wait I just remembered I killed a MSI Canterwood board by overclocking a Prescott 😁 That board deserved to burn! If I solder a new VRM in place of the burned one I bet it would work again.
I would however prefer a P3 Coppermine 1000(100), 1100 or perhaps even a modified Tualatin Celeron 1100 - 1400 mhz.
With any of those CPUs overclocking would be totally unnecessary. The P3 850 needs the bump in speed!
I would argue that the strain on the motherboard and the CPU would be worse with the Coppermine 1100 than with the Coppermine 850@952.
1100 mhz is just at the limit of what the (revised) Coppermine core can handle.
Reply 16 of 17, by TELVM
An over revved Cumine 1000 performs fairly good, not much worse than a Tually 1400-S.
But we need the right assortment of components (RAM, GPU etc.) to make it work stably.
Why to overclock? Well, because we can.
Let the air flow!
Reply 17 of 17, by Skyscraper
Nice!
I will have to update this build with the Aopen AX6BC or some other motherboard with 133/4 mhz pci divider!
I just tested two slotkets I bought with Coppermine P3 1000(133) CPUs mounted on them.
"pulled from working systems"
The slotkets will not work in any of the 3 BX boards I have tested so far.
I tested two of my own Coppermine CPUs with 100 mhz fsb on these slotkets aswell. No board will even post.
I bet the slotkets dosnt even support Coppermines.
The CPUs work but without slotkets they were expensive Coppermines...
The worst part is that I have already rated the seller because I bought 3 slotkets with CPUs a month ago, two with 1ghz CPUs and one with a 850 mhz CPU.
I only used one of the slotkets but it worked well so I thought they were all ok. At least the single working slotket works in all boards I have tried it in.
The working slotket is not of the same model as the other two but they are all "no name".
