First post, by matze79
my 486 Build is now nearly finished
- 486DX4 100Mhz AMD WB SV8T
- Lanner Industrial SlotCPU Mainboard
- 256Kb L2
- 64Mb (2x32Mb FPM Ram)
- EIZO Tseng ET4000 with 1Mb (ISA)
- NE2000 Clone Realtek 8019
- Soundblaster 16 Vibra
- 1Gb CF Card
- 1,44Mbyte Floppydrive
- LPT ZIP 100 Drive
- Windows 95A, IE 5.5
Sadly the case is nearly 6cm too short to fit Terratec Soundsystem EWS64 XL inside.
The ISA Backplane has 2 missing contacts, so i arranged the cards to get around this.
In Future is will replace them.
The RTC is reworked using a CR2032 on Top of the Benchmarq RTC. (No Photo currently)
The PC-Speaker on the Lanner Singleboard Computer was missing, soldered new one.
Looks like last Owner was too lazy to set the Watchdog Jumper to off.
Watchdog beeps when System has no external Activity (Network, RS232, LPT...) so he just forced it off the Board.
2.84 MiB
Original View, without Modification/Repairs.
With overclocked SX25 @ 33Mhz.
Featuring PC104 Slots :)
CPU is replaced with AMD 486DX4 WB.
2x 4Mb replaced with 2x32Mb FPM, i wanted use 2x64Mb FPM but Organisation of the modules is not supported by chipset..
192.61 KiB
337.92 KiB
Powersupply, with Ball Bearing Fan
364.15 KiB
Inside
368.94 KiB
NSSI
Reply 1 of 8, by matze79
92.7 KiB
Here is the Sysspeed Screen.
Reply 2 of 8, by keropi
heh nice!
I always liked these industrial PCs ,some are really slick but have limited space for expansions... so what u ganna put on the empty ISA slot now ?
Reply 3 of 8, by matze79
file.php?id=3517
Maybe i this thing ? but i have currently no time to continue my work 😒 i need to focus more on just one thing.
And another Slot with a SCSI Card and External CD-Rom Drive ?
i first need to fix Contacts on the Backplane.
i play Ultima Underworld on it currently, if i have some time spare.
i'm now on level 5 😀
Reply 4 of 8, by keropi
UW is a really really great game , kudos on the choice!
Now, what is this mystery card? BIOS extension?
Reply 5 of 8, by matze79
Disk On Chip 2000 😀
Reply 6 of 8, by keropi
Interesting, I jsut googled it. Seems it fits an industrial pc just fine 😁
Reply 7 of 8, by matze79
Today i tried to get Maximum of 128Mb RAM running.
Using two 36 Chip 64Mb FPM PS/2 Modules.
unfortunately it doesnt work... just beep.
But Handbook says 16Mx36 ?
http://mediaserver.voxtechnologies.com/FileCa … -2088843613.PDF
Reply 8 of 8, by matze79
Update:
- Now using AWE64 Soundcard
Fixed CPU Card:
218.63 KiB
Graphics:
213.61 KiB
Pins on Top of the TQFP where bend and had lose Connections, resoldered them.
Nice Picture on my Sun 22" CRT Monitor.
Sound:
214.25 KiB
Back of Casis:
131.32 KiB
Current Speedsys:
120.9 KiB
486DX4 @ 4x33Mhz - L1 8Kb WB, 256Kb WT L2, 0WS.
