First post, by Mr_ppp
- Newbie
Hi all
This weekend I had a bucketload of extra parts turn up to finally build a rig I had been longing for since forever..... The humble 486 build similar to what I had bitd
On Saturday morning I received the following motherboard as well as other parts such as 2x vlb I/O cards, 1x voodoo1 and 1xvoodoo2 card
It came generously with 2 x 16mb Simms so 32mb should keep me going for a while
Its been setup with a Holtek VLB I/O Card, Awe32 with 8mb ram, 20GB Maxtor drive and a throwaway cd drive until I find one that matches the setup
Heres the lovely little case its been shoehorned into, genuine NOS AT case being assisted by my daugher 😁
So far have DOS 6.22 and 3.11 tested as well as a quick blast on Win95 which seemed to work well but I'm limited as I don't have a mouse that works so a serial mouse is now on order 😀
I've also recycled the MSI-6156 board from my original Tiny Computers PC into a replacement case to setup some good old late 90s early 2000's gaming. There are a few suspect caps on the board but so far its working fine. Just need to find a decent AGP board to run as the 9700 pro I had is now faulty!
Amongst other bits and bobs I also received an Amstrad 1640 keyboard as I liked the look of it but it appears to have an XT connector, do adaptors exist?
Next job is to make early to mid 2000's and mid 2000's to late 2000's rigs. I have more than enough cases, motherboards and parts to do it 😁
