My Retro build
Reply 20 of 39, by nanospark
luckybob wrote:
No, but that isnt the point.
Also, if you decide to continue the heretic life, at least put a terminator in the 2nd slot.
But seriously, it looks awesome.
Sorry about my previous post. What does a terminator actually do? I looked up on Google "Slot 1 terminator" and I saw terminators with their own frequency, like this one:
http://www.pcandserverstore.com/Dell-100Mhz-S … 03E_p_1152.html
Does this mean anything?
Main PC: MSI Z87-G41 PC Mate|i5 4690K|32GB DDR3L-1600|EVGA GT 730 1GB DDR3|Sound Blaster Z|Inland Professional 120GB SATA III SSD, 2 x 1TB WD Blue WD10EZEX & 1 x 1TB WD Black WD1003FZEX|TSST DVD-RW|Win10 Pro x64
Too many retros to list!
Reply 21 of 39, by luckybob
Honestly, I'm surprised it works without it.
EILI5: Dual cpu systems need both slots occupied. To not do so, can cause system instability. This is mostly an issue with slot 1/2 and socket 370 setups.
Thankfully these terminators are very cheap. http://www.ebay.com/sch/i.html?_from=R40&_sac … =p2045573.m1684
That said, I think its so much cooler to have 2 cpus running. Get the S-spec off the top of cpu1 and get a 2nd. ^.^ (processors need to match)
Reply 22 of 39, by nanospark
luckybob wrote:
Honestly, I'm surprised it works without it. […]
That's interesting to know. I haven't experienced any system instability as of yet. In fact, the system runs great! I just don't see the need for it if the system already works and works well.
On a side note, I know that I had issues with the board before, but that was due to my own stupidity. I had all the system memory shadow options turned to "Cached".
3.91 MiB
What is now "Disabled" was previously set to "Cached" and I had problems with that.
Reply 23 of 39, by gdjacobs
Well, Intel SMP systems prior to i7 generation Xeons share the FSB which is why you need termination in the second slot or socket. Athlon MP systems can deactivate the bus of the missing CPU (although I've never tried this).
Reply 24 of 39, by nanospark
Here's the interesting part...I don't have a terminator card in the second CPU slot and the system works just fine. There have not been any BSODs or hangs at all...even with the weird RAM amount. Should I worry about this or should I not try to fix something that's not broken?
Reply 26 of 39, by nanospark
Anyway, setting aside that I'm running 1 CPU on a Dual CPU motherboard without a terminator card, how is the rest of the system otherwise?
Reply 27 of 39, by gdjacobs
Likely a happy accident. In fact, it might not work with a CPU in the other slot and it's likely limited in terms of FSB performance potential.
Reply 28 of 39, by nanospark
I'm actually not worried about it. All I know it that it works in MS-DOS and in Windows 98 without problems (and quite well, might I add).
Reply 29 of 39, by tayyare
What we do here in general is, first, creating our own problems by trying to fix something that's not broken, and then trying to solve the newly created problem. This is what we call our hobby. So you should start fiddling with it as soon as possible. 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 30 of 39, by gdjacobs
Fair enough. I'm just trying to make clear for other readers that proper termination is important and they shouldn't expect stability without. If it works without in your case then you're all set, but it's definitely not what your board manufacturer had in mind.
Reply 31 of 39, by nanospark
To be honest, I never knew that CPU terminators existed until I came to this forum. I knew that Rambus memory needs a terminator to function at all if you don't fill all the RAM slots...but that's another topic for another thread. Thankfully, I never had to work with Rambus either. 😜
Reply 32 of 39, by gdjacobs
It's like any other electrical communications line. If you don't match impedances, you get large attenuations and other large problems.
Reply 33 of 39, by Arctic
1) You don't need two CPUs for DOS / Windows 98SE. It does not support SMP! The other CPU would never be used in that OS.
2) There is nothing wrong with using only one CPU in a dual CPU system. It is an option to save cost and have the possibility to upgrade in the future.
3) Having 1 or 2 cpus in a slot 1 system does not affect the performance of the FSB of the first CPU.
I would be just happy if it works 😀
Reply 34 of 39, by gdjacobs
I agree, the CPU will not be used and the fact that it's missing will not affect performance so long as the bus has proper termination.
Reply 35 of 39, by chinny22
End of the day, your PC your choice.
My Asus duel slot 1 board happily works without the terminator. Hate how I know that as I had the original terminator all those years then lost it 3, 4 years ago.
BUT
Maybe not right away but do come join us in the SMP club, Win2k will play almost all you 9x games as well
Plus its where the real men hang out 😉
Reply 36 of 39, by nanospark
Recently I acquired a Pentium II 400MHz CPU (thanks oeurve for sending that to me! It is much appreciated! 😀 ). Unfortunately, I discovered that (due to chipset limitations) I can only run it at 333MHz with a 82.8MHz FSB. Also, I discovered that running PC133 RAM is pointless because of this limitation. I downgraded the RAM to PC100 with the same amount (320MB total). With that said, I have some CPU-Z screenshots to show off the specs:
CPU
16.37 KiB
Chipset limitations...
Motherboard
11.6 KiB
Definitely a PII Motherboard
RAM Slot 1
12.54 KiB
PC100 256MB...okay.
RAM Slot 3
12.68 KiB
...wait...why a 32MB stick?
RAM Slot 4
12.69 KiB
...another 32MB stick? That's where the 320MB comes from...
Reply 38 of 39, by luckybob
I really like that case. I've always been a lian-li fanboy sin the P4 era, but there are so many high-quality options now.
Reply 39 of 39, by nanospark
As far as I'm concerned, I would call this system complete...unless anyone thinks I should upgrade the video card at some point and if so, what video card should I put in here?
