My ASUS P2B Pentium II Build
Showcase your Retro PC / Build logs.
Re: My ASUS P2B Pentium II Build
Postby Almoststew1990 » 2017-3-27 @ 18:21
My heatsink, CPU and slocket have all arrived, and I'd like to set it up correctly (as correctly as possible anyway!)
I chose this slocket because a) it has lots of jumpers to set various frequencies and voltages and b) there isn't much choice of slockets on ebay UK. I have a Coppermine PIII 700MHz / 256k / 1.75 volts. How would I set this on the slocket and motherboard?
1) White Sliders
I assume the white sliders in blue box control the voltage, with the different settings seen in table in the second image? I understand (http://homepage.hispeed.ch/rscheidegger ... e_faq.html) these chips are quite happy over-volting. I chose a relatively high voltage chip to minimise this potential problem. Edit Can my motherboard control the voltage? it can go down to 1.8v in theory...
2) Jumpers
What are the five jumpers for? What does the Auto / Manual 'option' refer to?
3) Top Right settings
At the top right of the board as seen in image 2 it lists three options
1. Dual CPU M/B
2. Over Clock
3. VCore Selectable
I can see the nearby jumper to set whether overclocking is available (I assume some kind of multiplier lock protection?) But I'm not sure where the slider / jumper is to inform the board as to whether I am running two cpus, and that I would like to manually adjust the voltage!
I've set my multiplier to 7x on the motherboard (even though it shouldn't make a difference as it's multi locked I think?)
I don't want to just mess around with it to find the right setting because i'd like to avoid accidently putting 2.4v through it!
Intel 4770K 4.3GHz | 8GB DDR3 2133MHz | AMD 390X | 750GB EVO SSD
Intel E8500 3.1GHz | 3GB DDR2 | Nvidia GeForce 285 1024MB | 750GB HDD
Slot A Athlon 800MHz | 256MB PC100 | Voodoo 3 2000 | SB Live! 5.1
User avatar
Almoststew1990
Postby ScoutPilot19 » 2017-4-06 @ 14:32
He-He... Once I had a computer on a Asus P2Bf from late 1990s to early 2000s... Now have one on P3Bf with PIII-550, which is newest retro-pc in my collection.)
User avatar
ScoutPilot19
Postby Arctic » 2017-4-21 @ 05:35
If you use old slot CPUs, then always make sure to renew the heatsink compound.
That stuff becomes dry and very ineffective over the years!
Athlon XP 3000+ Barton @ 2.25GHz / 512MB DDR333 CL2 (2-2-5 1T) / Asus A7V333 2.0 / Voodoo 5 5500 64MB AGP 2x / Soundblaster 512 / Pioneer 105S / Win98SE
I am looking for Goldfinger Device - PM me!
User avatar
Arctic
Postby Almoststew1990 » 2017-4-21 @ 08:40
Arctic wrote:If you use old slot CPUs, then always make sure to renew the heatsink compound.
Yes you're right but unfortunately I have no idea how to get the SECC heatsink/ Cartridge off! I usually put fresh thermal paste on anything I buy second hand so it bugs me that I haven't been able to!
User avatar
Almoststew1990
Postby Richo » 2017-4-21 @ 23:17
thermal paste/pads become easier to get off when you heat them a little bit. I had this problem recently with 2 heatsinks so I took my solder iron and put the temperature at the lowest setting (200 degrees) and put it on the heatsink untill it became warm enough (I guess around 40 degrees or so) and then started turning the heatsink very carefully untill i could turn it 360 degrees and was able to take it off without using force (don't force it!). If you force it you may risk damaging the the chips.
TX97-XE, P55C, S3Virge, Voodoo, AWE64
GA-60XT, Tualatin, Albatron Geforce4 4200TI
A7N8X Deluxe, Barton, A9800 XT
Strix X99, Haswell-E, Gigabyte Aorus Pascal
User avatar
Richo
Previous
Return to System Specs
Who is online
Users browsing this forum: No registered users and 4 guests
