A P4 Rambus system, by AzzKickr
Reply 20 of 28, by AzzKickr
Okay so I made a breakthrough ! I still couldn't get it to work and after the like 9th format I decided to try the final option; I even had my Hercules Gamesurround Fortissimo II ready to replace the Live! Because I got sick of it.
So the final option: put it in another PCI slot and guess what: all of my issues suddenly vanished and the card installed and runs fine. Software errors on Creative's install packages are also gone. So I'm now installing/testing/removing all kinds of Creative software without issues.
I might do a 10th format now, once I know what works and what not, but this time it'll be with a smile on my face. And after that I still want to flash to latest BIOS too and start playing with the system 😀
Heresy grows from idleness ...
Reply 21 of 28, by AzzKickr
Aha another update, again from the iphone from the couch in front of the tv haha 😀
The machine is purring in the background doing its final install. I gave up on getting any of the 9x Creative software to work on 2k because I failed of course. So I'm going to use a later 5.1 installation CD, dated 2003, to get all of the features working.
I also flashed to BIOS 1008 beta 1 successfully !
So once it finishes the 2k install I can get to test and play fully !!
I'll update with more pics and info as it goes.
Reply 22 of 28, by AzzKickr
In the meantime a pic I took when I was assembling it
    252.56 KiB
    239.02 KiB
Reply 23 of 28, by sebaz_ri
AzzKickr wrote:
SP1 ? I'm on SP4 already ? Does that still apply then ?
Yup, this one http://www.majorgeeks.com/files/details/micro … ate_rollup.html
Actually it's updates after SP4, it doesn't have anything to do with SP1
Reply 24 of 28, by AzzKickr
Yup, I looked it up and installed it. Thanks for the tip !The only thing left for me to install now, is that "unofficial" SP5 so I'm as updated as I can get.
Reply 25 of 28, by AzzKickr
Okay so that unofficial SP is a no-go because it's not available in my native install language.
I did take some pics though;
    124.21 KiB
    194.73 KiB
    256.52 KiB
    160.05 KiB
Reply 26 of 28, by AzzKickr
Good thing the case is a version without side window haha 😁
And what better way to experience the glory of old with the proper input equipment 😎
    179.88 KiB
    170.02 KiB
Reply 27 of 28, by AzzKickr
Okay so I'm having a blast with this revived Rambus P4T ! I went online to search for a list of 2000-2001 era games to play and saw RTCW was a late 2001 title. Hoppedieday: let's play ! 😀
Installation went fine of course, installed the latest patch to support widescreen. Now for some reason the performance was really low. Very odd behavior. I thought to myself why is it running so bad ? Are the memories clouding my judgment and don't I remember it running this way in the past ? I was looking at 30 fps on full detail 720p. I admit I was a little disappointed so I went upstairs to the treasure room ( 😜 ) to see what else was in my collection that I could replace the Gen.1 Radeon with.
These turned up 😎
247.65 KiB
I was going to look at the Radeon 7500 to stay in the same time/performance era and was completely surprised when I opened up the box !!
This is an actual press release version with the press kit inside still !!
182.85 KiB
147.87 KiB
Reply 28 of 28, by AzzKickr
But before I was going to put it in, I wanted to give some overclocking a shot. So downloaded Powerstrip and got to work. I increased from 166Mhz to 175Mhz and fired up RTCW again. There was some improvement but not enough by far. So I kept playing it for a couple minutes until I reached the third level. All of a sudden the performance I knew it should have, was there !!! The fps counter floated in the 100+fps area as soon as the third level was loaded !!
So now I'm baffled ... I played a couple of minutes and the performance was just awesome, as already was in Q3 on this machine. I went back to Powerstrip and pushed for the 183Mhz of the Retail cards, which my OEM card handled just fine. Q3 Timedemo shows a hefty 82fps 1024*768*32 😎
So I'm going to look into the performance issue in the first two levels again just to get an ease of mind.
I also noticed that RTCW supports Truform; a feature I forgot all about. So those Radeon 8500's might come in handy in the next build 😀
And just for the porn value I'll share this one too:
212.77 KiB
