Show me your HP!
Reply 20 of 70, by kode54
How about my HP Stream 7? Can I call it retro because it's stuck on the Anniversary Update of Windows 10?
    451.13 KiB
Reply 22 of 70, by kode54
Sorry, gotta cancel that one. It's been so long since I last used it, I forgot that I successfully installed the Creator's Update on it a few months ago, and just updated it to the 1703 June cumulative update pack. Oh well, it's still quite an underpowered piece of hardware. For instance, it has 1GB of RAM, so it likes to run out of memory constantly.
Reply 24 of 70, by ODwilly
oeuvre wrote:
That's a sin, 1GB RAM on Windows 7 and onwards
Reminds me of the Windows 7 Starter Netbook days. Where having Norton installed would cause a "out of system memory" message and upgrading to 2gb led to a slightly less seen "cpu usage high" message instead.
Reply 25 of 70, by oeuvre
More pictures of the 7270 http://imgur.com/a/PrGcM
    635.36 KiB
Reply 27 of 70, by bristlehog
Netserver 4d/66 LE (Socket 2 486 DX2-66)
Vectra N2 4/25i (Socket 3 486 SX-25)
Vectra VA 180DT (Socket 8 Pentium Pro 180)
Hardware comparisons and game system requirements: https://technical.city
Reply 28 of 70, by SW-SSG
HP Compaq Presario 2140CA. Deceased.
307.7 KiB
Spec:
  • CPU: 1.8GHz Athlon XP-M 2200+ (Thoroughbred)
  • RAM: 1GB DDR-266 (upgraded from 256MB?)
  • HDD: 40GB 4200RPM (Hitachi 80GN)
  • ODD: LG CD-RW (replaced the faulty stock drive)
  • GFX: Radeon IGP 320M
  • Display: 1024x768px TFT
  • OS: WinXP Home
  • Power (Kill-A-Watt): 20.6w (idle), 69.1w (running Cinebench R10 CPU test)
I picked this up ~7 years ago out of curiosity. Was a really mediocre laptop... Keyboard was cheap feeling+mushy, the fans were hairdryer-tier loud, the screen's backlight was flickering at the touch due to a loose cable (albeit that's maybe the fault of the previous owner), etc. I still have the 13-disc recovery CD set; not entirely sure what to do with it.
The other HPs in this thread have lots more charm than this thing could ever have.
Reply 29 of 70, by Pasi123
HP OmniBook 530
1.48 MiB
Intel 486SX 33MHz
12mb ram
Maxtor MobileMax 131MB hard drive
Windows 3.11
X5670 @ 4.4GHz|P6X58D-E|24GB DDR3|GTX 960|750 EVO 250GB|4TB, 2x2Tb HDDs|Define R5|Win7
P4 HT 3.0GHz|GA-8SGXLFS|2GB DDR1|9800 Pro|2x 40GB Seagate|WinXP
Celeron 333MHz|Diamond Micronics C400|384MB RAM|Diamond Viper V550|6GB HDD|WinME
Reply 30 of 70, by oeuvre
Scraphoarder wrote:
Can we also show Digital and Compaqs? Digital was buyed by Compaq and Compaq merged with HP.
Yes! Also, Omnibooks look like pretty slick machines. I've never had one... how do they compare to Thinkpads of the same era?
Reply 31 of 70, by JidaiGeki
HP Vectra XU6/150 Pentium Pro. Pics were taken the day I picked it up in 2015 (it was being tossed out), still haven't cleaned it up properly and taken a nice pic. Bought and installed a second PPro 150 and stock heatsink, and picked up a similar era HP keyboard. Plan to try and max out the RAM and run NT4 on it, not sure what it has installed on it now (if anything).
1.31 MiB
1.44 MiB
Reply 32 of 70, by xjas
^^ What on earth is that blue zip drive from? SGI?
I didn't know they made any colours other than beige or black.
Reply 34 of 70, by Unknown_K
I have a HP Netserver (Dual P2's) and a HP MO Optical jukebox (fairly large). Need to dig them out someday for pics.
Reply 36 of 70, by tizzdizz
Here's one that I recently got running. Case has got some bumps and bruises but it works perfect.
It's a Vectra XM 5/150, with a Pentium 150 and 64 megs of ram. I installed Dos 6.22 on a 1GB hard drive, and then installed the SB16 (CT2970). Tested and works great.
745.6 KiB
1.07 MiB
Reply 37 of 70, by xjas
Here's my recent HP get, a once-mighty xw6000 workstation:
229.21 KiB
Would have been a good looking machine back in its heyday!
272.33 KiB
291.98 KiB
It came with some cool hardware - dual Xeons with hyperthreading, an eVGA GeForce 7600GT AGP, a 10 000 RPM 36GB SCSI drive, and 4 gigs of ECC DDR1 with this weird double-stacked chip arrangement.
254.43 KiB
The case can be used in a desktop or tower orientation by rotating the drive bays 90 degrees - very clever.
262.79 KiB
Fired it up and it did boot to the BIOS (note - removed three RAM sticks for testing, they all seemed to work though), but I couldn't get the HDD to spin up at all. The setup on these is this fantastically detailed DOS-style menu system.
However...
Reply 38 of 70, by xjas
247.31 KiB
Yuck!
319.09 KiB
Eww.
214.74 KiB
NOPE.
EVERY SINGLE capacitor on the motherboard looked like these. Frankly I'm shocked it even powered on, let alone booted to the CMOS setup in an intelegible way. They were even on the video card (which incidentally *was* dead, I swapped it out for testing above.)
311.25 KiB
So naturally I stripped it for parts. It yielded me some choice goods. The 2.8GHz Xeons are a great score for my currently-2.4GHz Asus PC-DL rig, those huge passive coolers will be a nice improvement and I think I can use the RAM in it too.
293.98 KiB
Here's everything that was left after all was said and done. (I also ended up tossing the dead HDD and one of the DVD drives which had a broken belt.) Note that I did save the video card after all; there aren't many caps to replace and they're easily accessible. A 512MB AGP card is rare enough that I'm willing to give a shot at getting it going again.
Sadly that cool dual-orientation case was in a really sorry state - filthy, with a lot of dented panels and broken plastic bits. It also weighed WAY more than it should have for its size - a good 10-12kg at least, which is about 8kg more than I felt like dealing with. It went back in the bin. Can't save everything, but at least some of this one will live on.
Reply 39 of 70, by chinny22
Duel PPro, This is my favourite so far!
