IBM NetVista / Lenovo ThinkCentre sleeper build
Showcase your Retro PC / Build logs.
Postby oeuvre » 2018-4-04 @ 19:34
Acquired a Lenovo ThinkCentre M72e and an IBM NetVista 6578 with a faulty motherboard.
Gutted most of the M72e
This is the final result!
Specs: IBM NetVista A40 6578-TAU case
Arctic F8 Pro PWM 80mm fan
80mm fan installed in front (pulled from M72e)
SeaSonic SS-350SFE 350W SFX power supply
Lenovo ThinkCentre M72e motherboard
Intel Core i5 3470 3.2GHz quad core processor
8GB (2x4GB) DDR3 RAM
DVD/RW drive
128GB Samsung SSD
500GB 7200RPM Western Digital hard drive
1GB AMD RADEON HD6570 PCIe video card
USB 3.0 PCIe card
Windows 7 64 bit
Spraypainted the metal part of the case. Closest color I could find. Hides the scratches well.
Case is really easy to open. Push 2 buttons on each side and lift it upwards.
The rear. I/O shield is kinda just stuck on there. Plugged in cables keep it in place. Those are the original NetVista PCI slot brackets.
Front has USB 2.0 ports on the bottom right corner.
Cover removed.
The guts
Another view
Messy cables galore. Might end up using zipties to settle those down.
The drives can be flipped easily.
Samsung SSD
Front panel pins needed some rearranging and trial + error.
Closeup of the power supply label.
IBM Model M made by Lexmark 42H1292
Corsair Harpoon RGB mouse
Here it is in action, stacked on top of a complete working original NetVista with a Pentium III 1GHz processor.
Customized BIOS logo
The desktop
System info
The desk, complete with old Altec Lansing ACS 5 computer speakers.
NetVista 4:3 wallpaper
NetVista 16:9 wallpaper
Black NetVista 4:3 wallpaper
Black NetVista 16:9 wallpaper
NetVista icon
NetVista icon with IBM logo
This was a lot of fun to make! There's a cooler sleeper with NetVista here. He inspired me to do this one. https://imgur.com/gallery/8HsYp
Dell Optiplex 330 Q8400, 4GB RAM, FirePro V3900 1GB, 640GB HD, XP
ThinkCentre Sleeper Ryzen 7 2700, 32GB, RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Re: IBM NetVista / Lenovo ThinkCentre sleeper build
Postby chinny22 » 2018-4-05 @ 14:42
IBM have pretty good upgrade path! Usually its just CPU's not whole socket upgrade ;)
Kinda cool having matching Retro and daily PC's and as highlighted in your pic, desktops stack nicely to save space, especially if its the same case.
I am actually surprised how well everything fits
User avatar
chinny22
Postby oeuvre » 2018-4-05 @ 22:08
Thanks! They're also built very well and are very sturdy.
User avatar
oeuvre
Postby KCompRoom2000 » 2018-4-06 @ 06:54
You, sir, have done it again. This is exactly the kind of build I would do if I wanted a modern system in a 90s style SFF desktop case. You've earned my seal of approval! :cool:
1988-96:SL-54U5|P233MMX|64MB|Virge325|YMF719-S
1995-98:P2B-VE|C433|192MB|Rage Pro|Voodoo2|CT4500/32M
1998-01:GX150MT|PIII-S 1400|512MB|GF4Ti4200|SB0350
2000-05:A8V|A64 3700+|2GB|RadeonX800
User avatar
KCompRoom2000
Postby oeuvre » 2018-4-07 @ 13:07
Aww ye, thanks!
Now in terms of PC projects not sure what to do next. Maybe call it a rest for a while.
User avatar
oeuvre
Postby Woolie Wool » 2018-4-11 @ 13:47
I assume the original drive was unusable because the Lenovo motherboard has no floppy controller? In that case, I'd add an LS-120 drive to fill the floppy hole.
User avatar
Woolie Wool
Postby oeuvre » 2018-4-11 @ 14:55
The SSD is where the floppy drive would be. No floppy controller since it is Ivy Bridge.
User avatar
oeuvre
Postby 386_junkie » 2018-4-16 @ 11:23
That's quite an upgrade!... Now a retro i5!... great to see, and amazing that it all fit's together so well.
User avatar
386_junkie
Postby oeuvre » 2018-4-16 @ 13:23
Thanks! Quite a lot of fun to put together.
User avatar
oeuvre
Return to System Specs
Who is online
Users browsing this forum: overdrive333 and 2 guests
