First post, by neocps1
hello
i am having a problem with L2 cache on a asus PVI-486AP4 motherboard
and a genuine 486DX4-100 and 256KB L2 cache in write back mode.
basically i ram access is slow (one 16MB 60ns).
cachechk reports 92ns for write and 145 for read.
speedsys says 70MB bandwidth
worse if i disable L2 cache in bios i get over 100MB bandwidth
in speedsys.
where am i wrong ?
thank you
Reply 1 of 6, by mrau
but does performance improve too? your cache seems a tad bit slow, so maybe settings are wrong?
Reply 2 of 6, by neocps1
if i disable L2 cache, system is slower. i followed the manual informations
i even swapped cache ram (not the two cache tag srams) 15ns without
improvement
Reply 3 of 6, by mrau
so everything is generally ok, just look at the settings; i dont remember the numbers but i do believe l2 might run faster
Reply 4 of 6, by neocps1
a lot faster? what should i expect ? maybe i am wrong and everything is ok
Reply 5 of 6, by mrau
see an example - imho this looks similar to yours - https://socket3.files.wordpress.com/2016/11/speedsys-486.png
just find cache settings in bios and check them;
the speedup will not be huge anyway - to be specific - by a quick google i found one example where l2 did 50MBps
Reply 6 of 6, by neocps1
thank you very much !
