First post, by arncht
i collected so much pc parts from this age, i have built a pc from them.
Mainboard Jetway J-656C Intel 430FX
CPU Intel Pentium 133 SY022
RAM Samsung 72 pin EDO 60ns 16M x2
VGA Diamond Stealth 64 Video 2001 2M PCI S3 Trio64V+
Soundcard Gravis Ultrasound 3.74 1M ISA
Soundcard Creative Sound Blaster AWE32 CT3910 rev 01 ISA DSP4.13, CT1747 OPL3
HDD Quantum Fireball 1280M IDE
ODD Sony CDU-77E 4x CD-ROM IDE
FDD Mitsumi
Case Baby AT (Pentium style)
PSU FSP SPI-250G
937.99 KiB
1.84 MiB
Overdoze of the demoscene
Reply 1 of 16, by Morc
Do you have more pictures of the case? I would like to see it as it is Baby AT
2018 Retro Rebuild: Pentium MMX @ 166MHz, LuckyStar 5I-TX1 rev: 2.0, 32MB, Verite 2200
Reply 2 of 16, by arncht
Jetway J-656C Intel 430FX (available from 1996, similar mainboards from 1996 q1).
i wanted a pc before the "classical" vx/hx age - with the first really good intel chipset, the 430fx triton. that was the only board what i found with real battery. it is not too fancy, but more practical. this revision of the board is a little bit newer, but with pb cache, the async cache was more typical at the fx boards (but it is still authentic in 1996 q1).
Intel Pentium 133 SY022 (available from 06.1995.)
the pentium 166 was also available in 1996 q1, but less typical - and for me it is more a "430hx" cpu.
Socket 5 cooler
typical mid 90s color 😀
1.69 MiB
16m would be a little bit more typical, but still authentic
Reply 3 of 16, by arncht
Sony CDU-77E 4x CD-ROM IDE (available from 12.1995.)
552.4 KiB
Baby AT (Pentium style - available from 1996)
a cheap case with turbo button, it fits to the age.
260.33 KiB
Reply 4 of 16, by arncht
Quantum Fireball 1280M IDE (available from 02.1996)
the mighty fireball w/o bad sectors - it was the fastest drive of this age.
357.51 KiB
Reply 5 of 16, by arncht
Diamond Stealth 64 Video 2001 2M PCI S3 Trio64V+ (available from 01.1996.)
the trio64v+ was new in the end of the 1995, later extremly popular on very cheap cards. just a mainstream card, but the most compatible and probably the fastest from 1996 q1. there is an extra connector.
1.31 MiB
Reply 6 of 16, by arncht
Gravis Ultrasound 3.74 1M ISA (available from 1994)
the latest gus classic, the best for demos. the earliest revisions from 12.1992, but this rev from 1994.
1.19 MiB
Creative Sound Blaster AWE32 CT3910 rev 01 ISA DSP4.13, CT1747 OPL3 (available from 02.1995.)
value awe32 with opl3, but no memory slots (for dos is useless - i use msdos 6.22 for this computer)
1.76 MiB
Reply 7 of 16, by arncht
it is there 😀
Reply 8 of 16, by Anonymous Coward
I am also really into the early Pentiums. By the time the VX, HX and TX came out the Pentium had kid of lost its lustre because the price had dropped to the point where basically anyone could have one. At some point I want to do a socket 5 system as well, but it'll probably be based on Neptune.
Pipelined burst cache is totally legit on an FX. I am pretty sure it was available from day one, at least I remember it that way from the PCmag reviews.
Reply 10 of 16, by arncht
i know, i always check the ages. the earliest 430fx boards in 1995 (like asus, and the intel zappa) came with wb cache, than end of the 95 / begin of the 96 released the pb revisions (before the hx/vx). i wanted an intel zappa, it also comes with normal battery, and it is a real socket 5 mobo. just a couple of late revisions support the p133 (mostly p75-120), it is rare now.
Reply 11 of 16, by arncht
sorry guys, i disassembled this rig. i put back the dx4 (log coming soon), and there is the mmx. the overlapping is too big.
Reply 12 of 16, by Anonymous Coward
Blasphemy!
Reply 13 of 16, by arncht
Blasphemy!
i use these machines, and i dont have too much space 😀
Reply 14 of 16, by arncht
finally! the intel advanced/zp (zappa) - with wb cache and socket 5. one of the first triton.
    590.78 KiB
Reply 15 of 16, by NostalgicAslinger
I also had this mainboard in 1995 (installed in a Vobis Highscreen Pentium 90) but without a L2 cache...
Reply 16 of 16, by Windows9566
Intel Advanced/ATX (Thor), one of the only ATX form factor 430FX boards that i have seen. the ATX socket 7 boards that i have usually seen have I430HX, VX, TX, and others like ALi, VIA, SiS, etc. chipsets, mine has the MR. BIOS flashed onto it, i was testing it on my chair cause i had nowhere else to do it on, i just ordered it and i was testing it which is what i do when i get a motherboard, i later used my broken ATX case as a test bench setup
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
