Reply 20 of 20, by PcBytes
- l33t
wrote:wrote:Try without GPU and RAM. If you get a long beep without RAM then the sticks may have gone bad.
I don't get any beeps unfortunately with GPU and RAM disconnected. I tried a 64mb DIMM in it's one DIMM slot but that didn't work either.
I'm still convinced it's something simple like a loose power connection or something. Or a dislodged jumper. At this point it is literally just P8 and P9 power and a speaker connected up.
Replace the jumpers then. I had instances where some of my jumpers were weak and wouldn't make good connection.
Most stiff and newer jumpers you can scavenge from various hard drives or newer (P4 - present) era motherboards.
