post up pics of your "computing area"
Reply 1200 of 2435, by Butler2679
Very neat. I like it!
What PC are you using with the CRT?
Reply 1201 of 2435, by oeuvre
New house, new setup!
Primary desktop PC. Specs and more pictures of it here https://imgur.com/a/p0OqPSM
Dell 25" 1440p IPS monitor, iKBC CD108 PBT Cherry MX Blue keyboard, Steelseries Rival 110 mouse, Altec Lansing ACS495 2.1 speakers (hopefully replacing them with JBL Creature III).
Dell 20" 2007fp monitor (4;3!), Logitech Internet Navigator keyboard, Corsair Harpoon RGB mouse, Altec Lansing ACS5 speakers. Pair of these nice little screw sets that are really good (and they have pentalobes for iPhones and MacBooks). https://www.amazon.com/dp/B009MKGRQA
Lenovo ThinkStation S20 W3680 hex core workstation (work in progress), Dell Latitude 7490 laptop, Dell Optiplex GXa (more info https://imgur.com/a/iNWC3E2 )
Project PCs, a ThinkStation S10 and a Core 2 Quad sleeper for sale.
My trusty junkyard office chair from a 99 Chevy Tahoe front passenger seat. Made it in 2011? or 2012 and it's very comfortable.
Reply 1202 of 2435, by bjwil1991
tenor.gif?itemid=5031964
Wait. A car seat as a computer chair? I should make a sofa using a seat from a van (3-seater) and a computer chair with a front or passenger seat from a car as well.
Reply 1203 of 2435, by oeuvre
It's not difficult! This one even swivels and reclines. I had some cheap low end task chair with pneumatic adjustment and the cushions were getting worn and torn. Unscrew the bottom cushion from the baseplate, discard the old cushion.
Acquire a car seat, cut a piece of wood, measure twice, affix it to the seat bolts. Make sure you put it towards the rear of the chair a bit for weight balance. Then attach the donor office chair base to the wood and bam. Make sure you do not pick a power-adjustable seat cause that would add a lot of weight and trouble. Unless you wanna go do some wiring and fix up a power source for it...
Reply 1204 of 2435, by bjwil1991
oeuvre wrote:
https://i.imgur.com/nWbpmT4m.jpg […]
Fancy work, man. Planning on doing that sometime when the time's right.
Reply 1205 of 2435, by oeuvre
Thanks! Keep us posted.
Reply 1206 of 2435, by Crank9000
oeuvre wrote:
https://i.imgur.com/MpYGYy1m.jpg […]
I've been pulling my hair out all day trying to decide what kind of monitor should I get for mostly 1024x768 and 1280x960/1024 gaming, how well does those resolutions scale on that 20" Dell? Crisp, bit of blurring, a lot of blurring? Oh how I wish I could get my hands on a quality 20"-22" 1024x768 monitor, but it's starting to look like I have to settle with a 19" 1280x1024 display and just deal with any blurriness.
Also like a lot of your setup, looks very homey.
Reply 1207 of 2435, by oeuvre
Thanks! It scales XGA and 1280x1024 pretty okay, but I try to use 1600x1200 when I can. For 98SE, the GXa is set at 1280x1024 and it looks quite okay.
Reply 1209 of 2435, by m1chelsen
Over the last weeks i have worked on a new project. In the back of our garage i have build a wall, so that i can have a dedicated retro PC room. The goal has been to build a room small enough that i can heat it up, without to have to pay a fortune, and big enough to store my retro hardware, and to host a constant retro LAN with 3-4 PCs.
Some days ago i finished building the table, and today finished to paint it 😁
The heatsource for the room ATM is my old main PC, which is mining crypto.
44929544_10218027268978412_2666121105273520128_o.jpg?_nc_cat=105&_nc_ht=scontent-amt2-1.xx&oh=ca4902d2a48cfae48416ae43dd0d89dd&oe=5C49F26E
44862235_10218027270098440_6620888207875637248_o.jpg?_nc_cat=107&_nc_ht=scontent-amt2-1.xx&oh=ce182e6467d8b909fde11dc068e51b1c&oe=5C482AED
44917846_10218027270858459_6753609723888533504_o.jpg?_nc_cat=106&_nc_ht=scontent-amt2-1.xx&oh=df72d008febb88428110963783eda941&oe=5C4CA239
44857142_10218027271738481_1391062219805949952_o.jpg?_nc_cat=106&_nc_ht=scontent-amt2-1.xx&oh=2da88553657cce8d3f70bbbd860f1a60&oe=5C4592DF
The next thing i will do, is to smooth out the floor and put some carpet onto it. After that maybe some more shelf, and then its time to put some more time into updating my trading blog with all the hardware that i have for sale / tradeing. When that is done, i will invite some friends over to play some retro games 😁
[ Console collecting blog: www.KonsolTing.blogspot.dk ] // [ Retro PC trading blog: www.3DfxQuest.blogspot.dk ]
Reply 1210 of 2435, by oeuvre
😮 impressive!
Reply 1211 of 2435, by BSU_bryT
WHITE N' NERDY 😉
Reply 1212 of 2435, by retrofanatic
BSU_bryT wrote:
WHITE N' NERDY 😉
...My favorite weird Al Yankovic song. Lol
Nice systems. Looks like PII and PIII systems. Is the one in the right older? Any 486 or socket 7’s in your repertoire?
Reply 1213 of 2435, by oeuvre
Fujitsu made desktops?
Reply 1215 of 2435, by treeman
treeman wrote:
this is my little corner in the garage https://preview.ibb.co/dwcqez/IMG_20180917_105148.jpg […]
finally swapped my 5x86 amd from a atx into a proper time period at case that I found on the street along with a working pentium 75.
Adjusted the led display to show 160/30, swapped the turbo button after burning the old one by connecting it to 12v on the motherboard instead of tb switch pins. Installed a atx psu and connected the switch from the atx -> at connector to the front power button.
Think my systems are complete and will stop at what I have
from the bottom
1. amiga 500
2. pentium 166
3. 386 dx40 in middle
4. and finally amd 5x86 @ 160 at the top
oh yeah made a home-made ide - > cf card front panel adapter from a old floppy disc front on the 586, yeah I know definitely not time period specific and probably a thumbs down for alot of people.... but I like it and its convinient
Reply 1216 of 2435, by Windows9566
my bedroom setup with a few retro PCs set up along with my main one
DOS PC(Left): Enlight EN-72500SA ATX Case, Intel AN430TX, Pentium 133, 32MB RAM, s3 Trio 64V+, SB 16 CT1740 DSP 4.05, 40gb Maxtor, DOS/Win 3.11 and Win 95 Dual Boot, Antec Basiq 350W
Mac Performa 6200CD(Next to the DOS PC): 75 Mhz PowerPC 603, 64MB RAM, TV Tuner, AV Card, 40gb Maxtor, System 7.5.Wi5
Win 98 PC (Below table): Deepcool Kendomen, ASUS P2B, Pentium III 500 Mhz, 256MB RAM, nVidia Geforce2 MX 400, 3dFx Voodoo 2 SLI, SB 16 CT2830 DSP 4.12, 40gb Maxtor, Windows 98 SE, Corsair CX550
Main Win 10 PC (Below table): Corsair Carbide, ASUS ROG Strix B350F Gaming, AMD Ryzen 5 1600, 16GB RAM, nVidia Geforce GTX 1060, Windows 10, Rosewill 550W Modular PSU
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 1217 of 2435, by treeman
I was about to say you need to fix up your turbo led display until realised its a gotek hehe nice setup, I like the white keyboard too matches up very nice
Reply 1218 of 2435, by oeuvre
seeing that windows 98 desktop on a monitor right above a performa is pretty funny
Reply 1219 of 2435, by Windows9566
i found that white AT keyboard at a thrift store along with the LCD monitor that's on top of the Performa 6200CD
IBM Thinkpad 760LD
