Reply 480 of 642, by vvbee
- Oldbie
Ironically, linux can run more games than the xp he went with.
wrote:Ironically, linux can run more games than the xp he went with.
Linux can run games, that's the truth, but let's not go that far. 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
...discounting the fact that XP can most 9x games natively, as well as the vast majority of 2000s titles and even some newer stuff. On Linux that'd only work with wine, or DOSBox which is just emulation.
"but but Wine something very new games"
take a moment and look at the specs of the machine I have- it's Socket 462. Do you really think very new stuff will run on a Socket A PC? they won't.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
If xp runs games better than linux on your system, use xp, dead simple.
wrote:If xp runs games better than linux on your system, use xp, dead simple.
It was more like "more" if not "better"... 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
In that case go with linux. Choices, choices.
wrote:wrote:If xp runs games better than linux on your system, use xp, dead simple.
It was more like "more" not "better"... 🤣
eh, some games of that era do have dodgy wine support irc so it is almost certainly better and more
What's wrong with Dual boot? I have my rig set up that way.. XP 32 bit and Debian 64 bit.. Best of both worlds.
Then again that's not the most high end XP rig in the world, I would put XP on it myself as a first choice for gaming(and I say that with Linux as my main OS).
Sup. I like computers. Are you a computer?
wrote:What's wrong with Dual boot? I have my rig set up that way.. XP 32 bit and Debian 64 bit.. Best of both worlds.
I had my XP box just like that a few years ago: XP, Fedora and Mint. It was working beautifully, but I somehow screwed up (boot sectors and mbrs and such) and now I can't even finish installing either of the Linux builds, they just hang in some place. I'm not good with them, and I clearly don't remember how I did it in the first place (which was a big challenge and looong process of trial and error).
By the way, anyone knows the "dd" command which will delete the Windows(?) RAID string that is placed in HDDs that were used as RAID arrays in the past? This is something I can't remember and one of the things that freaks out fedora/mint installations. This is not deletable with mbr rebuild commands or formatting.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
This is my gaming rig, it's a bit out-of-date, but still runs everything I want at max settings.
It has a 4GHz i7-4790k CPU and GTX 980 GPU (Both liquid cooled on a custom loop with their own radiator) 16GB RAM (with activity LEDs) a 1TB PCI Express SSD, and a Sound Blaster Z connected to 5.1 surround sound.
Got a pre order on one of these that arrived today. Did a little bypass surgery to test it out. Next is to install the new EK Vector blocks and plumb it in.
wrote:This is my gaming rig, it's a bit out-of-date, but still runs everything I want at max settings.
While the processor may be a couple of years old, it's perfectly fine for modern games. I personally use an i7 2600 and even it runs modern titles well.
Sandy bridge CPUs are still pretty okay for modern gaming, as long as you have a decent GPU and 8GB or more RAM.
Coolermaster Centurion 5 Case
Phenom II x4 945 95W TDP with 125W TDP stock Phenom II cooler
8GB 1333 mhz DDR3 (4 x 2GB)
EVGA GT 720 1 GB DDR3
1.8" Kingston SSDNow 128 GB
640 GB WD Black
LG DVD Writer
Corsair VX 550W
Windows 10 64 Pro
GT 720 is a GT 710 with a lower core clock. It's 8x PCI-E compatible card so it doesn't take up the full 16x slot.
wrote:Sandy bridge CPUs are still pretty okay for modern gaming, as long as you have a decent GPU and 8GB or more RAM.
Yeah. I've got a GTX 950 and 16gb of ram with my 2600. It runs decently well, but the psu is pretty bad.
My current rig is an i7 2600S 45W ES/GTX1050 Ti KalmX/8GB DDR3/Win10 sleeper:
The case is from a ~2007 brand name office PC called Depo Neos or some such. I like its conservative dimensions and front panel design (which was clearly ripped off of the Dell Dimension XPS T line), and the involuntary "hot-rod" look to its side due to the large CPU cooler 😀
Also involuntary is that it shares the same case model with my only retro PC:
Both are - while not truly "silent" - quiet to the point when it is impossible to tell if they're turned on or not without listening closely, thanks to overkill PSU's, undervolted CPU fans, passively-cooled graphics cards and non-mechanical storage drives).
Got the 2080 Ti blocks on and card installed. Also installed matching CPU block so the carpets match the drapes...
